Hiding Tabs Using CUI
The Hide Tabs community project is one of the more popular projects Aras Labs has published. It demonstrates how to hide a relationship tab on a specific item form by using a custom JavaScript method. This is useful when you want to limit the use of a specific relationship to only a handful of users. However, this approach comes with some downsides. If your ItemType uses several forms, you must add this same method to each individual form. Additionally, using a custom method at all requires some overhead and maintenance. As of 12.0 SP4, it is now possible to hide tabs without using any custom code at all. In this blog post, we'll cover this new approach that uses CUI in detail. You can also look at the most recent version of the Hide Tabs by Identity community project for an import containing all of the configuration changes we'll make in this post. In these examples, we'll be configuring the Part BOM and BOM Structure tabs of the Part ItemType to be only visible by members of the Administrators identity. Hide the Relationship Tab The original approach of using a custom method involved checking if the current user did not belong to a specific identity. In this case, the tab would then be hidden from that user. With the new approach of using purely CUI, this concept will be flipped entirely. We'll start by hiding the tab for everyone, and then configure the CUI of our ItemType to display the tab for only our Administrator users. Let's take the first step of hiding the relationship for everyone. Log in as admin Go to TOC > Administration > RelationshipTypes Hide the Part BOM relationship Search for and open Part BOM Edit this relationship and check the Hide for All flag In the item toolbar, click the button and select Properties Click Copy ID and store this somewhere as we'll need it later Repeat the steps above for the Part MultiLevel BOM relationship Use CUI to Display the Tab If we go and open a Part now, we can see that the Part BOM and BOM Structure relationship tabs are no longer visible. This is currently true for every user, so now let's re-enable these tabs for only our Administrators. To begin with, we'll need to add a CUI section to tell the Part ItemType that it's going to have custom tabs. Navigate to TOC > Administration > ItemTypes Search for and open the Part ItemType Select the Client Style relationship tab and open the item here This is the item that controls all of the ItemType-specific CUI for Part In this Presentation Configuration, select the cui_PresentConfigWinSection relationship tab Create a new related item here to indicate that the Part view will have custom CUI Classification - Data Model Name - labs.part.itemview Location - ItemView For Identity - World Open this new related item In the cui_WindowSectionControl tab, add a new item to represent the Part BOM relationship Type - Tab Element Control Name - labs.part_bom.tabelement Label - Part BOM This will be the label on the relationship tab Additional Data - {"relTypeId": "159C6D88795B4A86864420863466F728"} The ID here should be the same one you copied from the Part BOM RelationshipType earlier Parent - ItemView.RelationshipAccordionTabs Action - Add For Identity - Administrators This is the Identity that will be able to see this tab Repeat the same steps to add a new item for the BOM Structure relationship Type - Tab Element Control Name - labs.bom_structure.tabelement Label - BOM Structure Additional Data - {"relTypeId": "567E4149FBF74DACA0B0C4C9B1E79A3B"} This should be the same ID you copied from the Part MultiLevel BOM relationshiptype earlier Parent - ItemView.RelationshipAccordionTabs Action - Add For Identity - Administrators Save and close this item Save and close the Presentation Configuration After following these steps, it should look similar to the screenshot below. Confirm the Changes Since we're already signed in as admin, let's open a Part to check if we can see these tabs now. While we're at it, let's also make sure these tabs are hidden for a user who is not an Administrator. When we log in as this user and open a part, we indeed can no longer see the Part BOM or BOM Structure tabs. Conclusion CUI is a powerful tool to have at your disposal that is only growing in functionality and responsibility. If you're looking for more information on how to use CUI to configure other areas inside of Aras Innovator, please check out all of our blog posts on CUI.342Views0likes0CommentsCustomizing Item Menus with CUI
In previous blog posts, we've covered how to add custom menu items like buttons and shortcuts using the Configurable User Interface (CUI) data model introduced in 11.0 SP7. Using this same data model, it's also possible to add menu items that are specific to individual ItemTypes that you want to have special functionality.355Views0likes0CommentsDisplaying HTML in Aras Innovator
Whether it's enabling administrators to create custom Forms or change the default user interface through CUI, Aras Innovator allows for easy configuration of the out-of-the-box client. However, there are still times when a particularly complex UI wil...560Views0likes0CommentsTech Tip: Disable a Menu Button Using CUI
In previous blogs posts, we've learned how to add a new button to our menus as well as add new keyboard shortcuts. Both of these lessons are great when we want to allow our users to perform new kinds of actions, but how do we prevent our users fr...351Views0likes0CommentsCreating a Custom Refresh Button Using CUI
With the introduction of CUI in Aras Innovator 11.0 SP7, you can now manage the appearance and functionality of the User Interface directly through the Aras Innovator client. In this post, we will learn how to use CUI to add a custom refresh button t...242Views0likes0CommentsTech Tip: Style Non-Current Items
It's easy to lose track of whether you're looking at the current version of an item, especially when opening an item from a relationship or item property. This tech tip demonstrates two ways to show whether an item is current at-a-glance using form s...88Views0likes0CommentsCustomizing Your Aras Forms: Part 2
As we covered in the first part of our blog series, the possibilities for your Aras forms extend beyond the configuration options in the Aras Form Editor. In this article, we'll see how we can combine a little CSS and Javascript to apply custom ...365Views0likes0Comments
