xClassification: Manual Re-Structuring/Editing
Hello Everyone, I am currently struggling with xClassification and I need some help/insight. My current client created an xClassification structure, xClass and xProperties, sometime ago from and Engineering context. As a corporate goal they are now challenged to create an Enterprise xClass and xProperties structure that will be used to publish, from PLM, to a Convergence system, Oracle EBS, and Oracle Fusion using an Enterprise classification structure. So My current challenge is to updated the current xClass-xProperty structure to the the hierarchy while preserving all the current/existing xProperty data. Thus far I have been able to: 1) Rename all xClass items required 2) Generate the [From_RefId - To_Refid] string that establishes the xClass Hierarchy xClassificationTree.classification_hierarchy 3) Align xClass_xPropertyDefinition with xClass_xProperty_Flatten with xClass.xproperties_sort_order The ClassificationTree loads as shown below But when I try to save the xClassification tree I get this error: I found the Error String in {Aras.Server.Core.dll}. internal class XTreeMigrationModel but, I'm not sure what it is actually doing to throw the exception. Below is the code snippet that throws the exception.62Views0likes1CommentReference an Engineering Parts xClass xProperty as Engineering Master Data
My client uses the Part Itemtype in 2 contexts Engineering and Manufacturing. The requirement is that all xClass-xProperty data is populated and maintained on the Engineering Part and the xClass-xProperty data on the Manufacturing Part is rendered using the Engineering Parts Id. The Engineering Part that will be used for the reference will be the Latest Released Generation. The illustration demonstrates the relationship between the Engineer Part and its Manufacturing Parts. What I do know is that all the xProperty Data is store in the table set [xp.XpropertyValues#] as shown below. All xProperties can be acquired using the ID of the Engineering Part (I have a SQL query that can do this for reporting for a BOM structure). I have modeled the js/ts methods but I can't figure out how to apply them in this use case. What I can't figure out is: 1) What are the options for rendering the xClass-xProperty container on the Part Manufacturing Form 2) How to populate that container using the ID from the latest Released Engineering Part Any help/ideas would be greatly appreciated. Thanks Scott52Views0likes0CommentsRefreshing xClass Field on Form in Field Event OnChange
So I wrote a client side method so when you change the Classification of a part, it selects a matching xClassification. This part is working, except the UI isn't updating with the selection of the xClass, so its prompting me to enter the required properties for my xClass, but I can't see them. How do I get the xClass field on my form to update so that it displays my new selection? Several examples used aras.uiReShowItemEx() but that pulls from the database, but the xClass selection has not be saved to the Part yet... so its blank. It looks like form.populate() is the right idea because its not pulling from memory but everything I try returns form as null...Solved339Views0likes4Commentsxclassification dialog from custom method
hello i'm begining a project, the idea is to have a an action launch a dialog to select a xclass. I would like to launch the same dialog as the one that pops up when adding a part xclass and x property(see below): after the user selected a class i want to retrieve the name of the class he chose. The following step is to have a second dialog (depending on the classification chosen) this second dialogs might be hard coded or dynamically buit i'm still unsure and they are going to look like the form used to fill the xproperty after you choose your part class but slightly different: i want to add a column of check boxes for future business logic. i've tried to search for the xclass tree selection dialog but couldn't find it i've tried to display some that i could find in the code tree but without sucess, i used the dialog api, here is my code: var param = { aras: top.aras, type: "HTMLEditorDialog", sHtml:"here i've tried to put just the name and the full path but it didn't seem to work as even when i changed form i was always getting same form opening ", dialogWidth: 1000, dialogHeight: 500, }; // This will be called after the dialog is closed function callback(res) { if (res) { alert(res + " loves learning about new opening HTML pages as dialogs!"); } }; // Open the dialog var topWnd = top.aras.getMostTopWindowWithAras(); var wnd = topWnd ? topWnd : window; wnd.ArasModules.Dialog.show('iframe', param).promise.then(callback); any help is welcome thanks lucas1.6KViews0likes1CommentDisplaying In-Line Units for xClass xProperties
Migrating from another system, they have a lot of properties that also include units. Like this: How can I modify the Extended Classification display to show units in line like this? My plan so far is to build out ItemTypes for each type of measurement (Length, Temperature, etc) similar to the default 'Measurement Units', including a conversion value to whatever base unit is decided. (Anyone know why there is a 'viewer' on this itemtype?) So then I could build xProperties linked to the ItemType for that type of unit, and add it to the xClass which would put the UoM as another line in the xProperties So the question is how would I modify the xClass Display so that I could pair up the two properties and get an in-line display of the units? (and do it for some properties, not others, and for many properties within an xClass)182Views0likes1CommentLoad xClass and xProperties, and link xProperties to multiple xClasses from AML
We want to load 1k+ xclasses to Aras, we are talking about 4k+ xproperties here. When we are running AML for creating relations xClass_xProperty_Flatten and xClass_xPropertyDefinition to link them to class tree, it fails with error : <faultstring><![CDATA["xClass_xProperty_Flatten" can be added or deleted or updated only in XTree context]]></faultstring> <detail> <af:legacy_detail><![CDATA["xClass_xProperty_Flatten" can be added or deleted or updated only in XTree context]]></af:legacy_detail> <af:exception message=""xClass_xProperty_Flatten" can be added or deleted or updated only in XTree context" type="System.ArgumentException" /> </detail> I can load property definitions, but not classes, but can’t map the properties to classes. How can we mass create and reuse these xProperty definitions in more than one class from AML, by creating relations correctly?2.5KViews1like2CommentsCan you Remove xClass relationship with onChange field event?
I'm trying to clear out the xClass relationship when the class of a part is changed. The code I have below is ran on the filed event of the drop down onChange, however it doesn't remove the xClass relationship. var rootItem = document.thisItem; rootItem.fetchRelationships("Part_xClass"); var xClassRelationship = rootItem.getRelationships("Part_xClass"); if(xClassRelationship.getItemCount() > 0){ var current = xClassRelationship.GetItemByIndex(0); rootItem.removeRelationship(current); } return rootItem;3.6KViews0likes1CommentHow to Update the value of xClasss xProperty by AML or API?
Hi Eli, How to Update the value of xClasss xProperty via API or AML? I can get the value of an xProperty via MyItem.getProperty("xp-MyPropertyName") or AML. But I failed to update xProperty this way. Item MyItem = innovator.newItem("Part","edit"); MyItem.setID("xxxxxxxx"); MyItem.setProperty("xp-length","10"); MyItem.apply(); Lin6.3KViews0likes3Comments
