- Former_MemberAccelerator IIIHi Lin, Code looks right. I usually look at the returned Item from MyItem.apply();
MyItem = MyItem.apply(); if ( MyItem.isError() ) { // have a look at the error string or do something }This should give you some clues what is going wrong with the update. Cheers, Brian. - eli_donahueCommunity ManagerHi Lin, If your xProperty is already defined, try setting the set attribute on the xProperty like this:
Item MyItem = innovator.newItem("Part","edit"); MyItem.setID("xxxxxxxx"); MyItem.setProperty("xp-length","10"); MyItem.setPropertyAttribute("xp-length","set","value"); MyItem.apply();This code will result in AML like this:<Item type="Part" action="edit" id="xxxxxxxx"> <xp-length set="value">10<xp-length/> </Item>
Eli
Eli Donahue Aras Labs Software Engineer- ddidonatoCreator II
Hi Eli,
We added extended classifications to our PART itemtype after we had already established thousands of records for parts. How can I do a global update to all parts and set the "extended property value". I try to create a method to update parts , but it gives me an error "You tried to perform "update" operation against not defined Extended Properties". I'm assuming because the parts were created before we setup "extended classifications"
