srmorrisonearthlink-net's avatar
21 days ago
BatchLoading Properties that have LF (linefeed) characters in their data
My client has Oracle EBS data that has LF characters in their attribute metadata that needs to be loaded into a Part itemtype.
How would I do this with the BatchLoader?
Thanks for the guidance.
Scott
  • I should not be a big issue. I have imports with \n\r all the time.
    How does your LF char look like when you open the import file with a text editor?
  • Hello Angela.
    Thanks for responding.
    It only shows as LF character or \n and not the CRLF at the end of the line. When I see it in the preview Batchloader preview, the previewer shows the extra lines as a result of reading the LF character as shown below.
     So you think it will load as required instead of whats shown in the preview?
    Thanks
    Scott
      Hi Scott,
      thanks for the image! If the batch loader sees the data this way, the import will probably fail.
      Do you use the correct Delimiter for your data?
      I would test it with a very small amount of data (=1 item) on a test server first.
