How to find the package definition the item is part of?
As the question states. When I try to add an item the error message states "ABC is already added to the another Package Definition". I need to find which package this item is in and remove it because I need it another package. Thanks100Views0likes2Commentsexport for existing items
hello, i have been diving into packaging and exports lately but there is something i can't figure out. it might seem easy but it's not said clearly anywhere i looked. So, let say i customize an already existing item like Parts, i had actions, modify the forms and i want to export my work the next step i need to follow are: 1)since itemType Part is in package "com.aras.innovator.solution.PLM" i had to this package the actions, methods, forms and all items that i could have added to the part item types. 2)then using the aras export tool i can either export the whole package or only the things i just added to the package. please tell me if i'm right wrong or if i'm lacking some part. thanks, lucas3.1KViews0likes4CommentsItem Type issue after Import
Hi Community, Strange issue here. I exported an item type and it necessary relationships over from my development server to my test server. I can create items in the item type just fine. What I can't do - Edit the item type - presented with error "The method 'cui_ivicb_edit_click' failed." The claim flag still checks but no changes can be saved as the UI never updates to allow Save/Done/Discard. I thought this could be a cui issue but the configuration for this matches as well. Nothing special was done to any of the CUI items. The name field is blank on the item type along with a few other discrepancies from the original item as seen in development. When using the Search for or Home screen tile button, the search grid does not load. I have tried re-verifying relationships and exported items. Everything lines up. Any suggestions would be helpful.Solved3.1KViews0likes3CommentsExport Relationships to Import to Another ItemType
Good day all. I would like to export all of the Relationship info from one ItemType so I can import it to another ItemType. Currently our database is configured so the Parts List (BOM) is a document and not part of the Part, both are custom ItemTypes. I would like to be able to export the BOM information from the Parts List so I can add it to the Part (trying to bring our database closer to OOTB). Thank you for any recommendations that you can provide.2.3KViews0likes1CommentDEV - Optimizing ways and means of Import/Export
As an admin/developer of Innovator I want to pretend I'm working in a repo where I can identify and track changes, or at the very least see all my changes so I can not miss a thing on Export. I'm still a noob. I'm not unfamiliar with Dbs of various flavors, and while I've a love of JS, I'm well versed in PHP and have used some other programming languages. I'm especially a fan of recognizing needs and making work easier and more streamlined. For me, making life easier might come in the form of a bash one-liner, or a NodeJS server/app, or PostMan collection. I think Import/Export is lacking and there should be one tool in the end, and that tool should be built-in, not dissimilar to Nash Utility, but a whole lot prettier! Here's a summary of why I believe things should change. IMPORT In my experience there's a mess when working with other developers in that sometimes a packages infers it should be imported using Nash Utility, or sometimes I'm to use the package tools Import tool. In my most recent battle I was given a package and the developer specified I had to use v12SP6 import tool. I just grabbed the latest, which I think was that associated with the SP9 package. It didn't work, so I methodically tracked every step and took screenshots and all. Well, it ended up that when I got to the step that emphasizes a specific SP Import Tool, this time, I went to the FTP site and grabbed the Import tool of SP6, specifically, and the import worked. One of the greatest difficulties that I thought absurd during this headache was that I couldn't even just simply select the text of errors in the popup of the Import Tool, so I always had to go open the log to get to the error. To me, that's silly. All of these things have been very frustrating and highlighting a deficiency. And, then there's the challenge of the necessity of doing things this way. EXPORT Well, I would bet many people have gone through this, but I just made my first package! I click all around and gather the pieces. The thing is looking robust and I think I'm done. I goto the Export tool and specify my package, and I check the box to export dependencies. I'm thinking there's no way I can export this new ItemType wrong now. The created package will not import to the same Db, after restoring to pre-work, that my work started on. This is very frustrating. After days I just use Nash as an alternate means and start pasting the XML and importing, slowly, while sometimes importing the new pieces into the Db in the wrong order. I finally get to the new ItemType itself! My first ItemType! ...and I'm missing my Methods and my Lists from my export. I just missed them and they weren't pulled in, and I can't restore the Db I backed up where I did my work, exported, and replaced with the original Db, pre-work. I don't know why... but, ouch. I can't get to pieces of my first ItemType. ---------- SOLUTION DISCUSSION First of all, I wish my employer would pay me to just fix whatever I run into. Isn't that a dev's dream? I don't mean Aras, I mean like just spend my day on StackOverflow and fix ***. But, that's not the case. I never want to miss an ItemType -OR- any relationships be it Method, List, Permissions, Identities, and even PolyItems, etc. Miss nothing, always! I want to be able to see a picture of all my changes from a certain date like I'd checked out a branch. In the end I think there should be no need for separate Import/Export programs! There should be something to Export that utilizes authentication of "root" that works in the browser (like a Nash Utility) that can bundle changes a user has selected. That bundle should work as an Import in a browser-based tool that either: Knows the set order things need to import in -or- is order agnostic. I'm using the proper order, I think. Here's a solution in the works. Feel free to contribute! // Find all Innovator edit since time const inn = this.getInnovator(); // Create Dialog.] const param = { aras, dialogWidth: 250, resizable: true, title: 'Modified Since' }; const wnd = aras.getMainWindow(); const dialog = wnd.ArasModules.Dialog.show('div', param); ///////////////////////////////////////////////////////////////////////////////////////////////////////// // TODO: Edit to query for any new ItemTypes and tack onto itemTypes list to look for new instances. // ///////////////////////////////////////////////////////////////////////////////////////////////////////// const itemTypes = ['LIST', 'SEQUENCE', 'REVISION', 'VARIABLE', 'IDENTITY', 'MEMBER', 'USER', 'PERMISSION', 'METHOD', 'EMAIL MESSAGE', 'ACTION', 'REPORT', 'FORM', 'WORKFLOW MAP', 'LIFE CYCLE MAP', 'GRID', 'ITEMTYPE', 'RELATIONSHIPTYPE', 'FIELD', 'PROPERTY', 'VIEW', 'SQL', 'METRIC', 'CHART', 'DASHBOARD']; const badgeStyle = 'style="font-weight:200;background:#999;color:#fff;border-radius:5px;font-size:12px;padding:5px;margin-left:.5em;letter-spacing:.1em;padding-bottom:3px;position:absolute;top: 12px;text-align:center;"'; const table = 'style="display:table;width:100%;border-collapse:collapse;"'; const tableCell = 'style="display:table-cell;border:#000 1px solid;padding:.25em;"'; const tableCheckbox = 'style="display:table-cell;border:#000 1px solid;padding:.25em;text-align:center;"'; const tableHead = 'style="display:table-cell;border:#000 1px solid;font-weight:bold;background:#000;color:#fff;padding:.25em;"'; const yesterday = (d => new Date(d.setDate(d.getDate() - 1)).toISOString().split("T")[0])(new Date()); // let dateInputDiv, dateInputDOM, dialogDOM, contentDOM, changesList, changesListText, titleDOM, formFooterAdded = false; // const alternateRowBG = (i) => `style="display:table-row;${i % 2 ? 'background: #e7e7e7;' : ''}"`; const formatRow = (itemType, id, name, modifiedOn) => `<div ${tableCheckbox}>${getRowCheckbox(id, name, itemType)}</div><div ${tableCell}>${name}</div><div ${tableCell}>${itemType}</div><div ${tableCell}>${modifiedOn}</div>`; const getBadge = (num) => `<span ${badgeStyle}>${num}</span>`; const getRowCheckbox = (id, name, itemType) => { const checkboxName = `${name}---${itemType}` return `<input type='checkbox' id='${id}' name='${checkboxName}'>` }; const styleMe = (elem, styles) => { for (const [key, value] of Object.entries(styles)) elem.style[key] = value; }; // Build date input text box/style it const buildDateInput = () => { dateInputDiv = document.createElement('div'); const dateInput = document.createElement('input'); dateInput.id = 'modified-since-date-input'; dateInput.type = 'date'; dateInput.max = yesterday; styleMe(dateInputDiv, {paddingLeft: '16px', paddingRight: '16px', maxHeight: '70vh', overflowX: 'hidden', overflowY: 'auto'}); styleMe(dateInput, {width: '222px', marginBottom: '16px', marginTop: '8px'}); dateInputDiv.appendChild(dateInput); }; // Loop through the returned methods and return the list const buildChangesTable = (value) => { changesListText = ''; const changesTable = document.getElementById('changes-table'); if (changesTable) changesTable.remove(); let changesList = `<div id='changes-table' ${table}><div ${alternateRowBG(-1)}><div ${tableHead}> </div><div ${tableHead}>Item</div><div ${tableHead}>ItemType</div><div ${tableHead}>Modified On</div></div>`; let sinceDate = value + 'T00:00:00'; let rowCount = 0; for (let i = 0; i < itemTypes.length; i++) { const itemType = itemTypes; const item = this.newItem(itemType, 'get'); item.setAttribute('select', 'id,name,modified_on'); // FIXME: We want unique results. It seems IT properties are heavily versioned. // groupBy doesn't error, but doesn't appear to do anything // item.setAttribute('groupBy', 'id'); item.setProperty('modified_on', sinceDate); item.setPropertyAttribute('modified_on', 'condition', 'gt'); const results = item.apply(); if (results.isError()) { const errorDetail = results.getErrorDetail(); // No items of type if (!/No items of type/.test(errorDetail)) { aras.AlertError('results.isError(): ' + errorDetail); return; } } for (let j = 0; j < results.getItemCount(); j++) { const id = results.getItemByIndex(j).getProperty('id', '-id missing-'); const name = results.getItemByIndex(j).getProperty('name', '-name missing-'); const modifiedOn = results.getItemByIndex(j).getProperty('modified_on', '-modified_on missing-'); const row = formatRow(itemType, id, name, new Date(modifiedOn).format('MM/dd/yyyy HH:MM')); changesListText += [id,itemType,name,modifiedOn].join() + '\n'; changesList += `<div ${alternateRowBG(rowCount)}>${row}</div>`; rowCount++; } } changesList += '</div>'; styleMe(dialogDOM, { width: '720px' }); // TODO: Test that this: Why can't we assign this once upon opening and keep the ref? contentDOM = document.querySelector('.aras-dialog__content'); dateInputDOM = document.querySelector('#modified-since-date-input'); titleDOM = document.querySelector('.aras-dialog__title'); // titleDOM.innerText = 'Modified Since ' + value; titleDOM.insertAdjacentHTML('beforeend', getBadge(rowCount)); const viewButton = document.createElement('button'); viewButton.innerText = 'View CSV'; viewButton.classList.add('aras-button'); styleMe(viewButton, { position: 'absolute', top: '10px', right: '40px', paddingLeft: '.5em', paddingRight: '.5em', background: 'transparent', color: 'darkblue', boxShadow: 'none', border: 'none', cursor: 'zoom-in' }); viewButton.onclick = () => { const resultsWindow = window.open("about:blank", "_blank"); // contentDOM = document.querySelector('.aras-dialog__content'); resultsWindow.document.write(`<pre>${changesListText}</pre>`); }; titleDOM.appendChild(viewButton); // contentDOM.innerHTML += changesList; dateInputDOM.insertAdjacentHTML('afterend', changesList); // FIXME: Or... understand me? I don't know why the onchange gets dropped between calls to this_function...? But, it does, so: dateInputDOM.onchange = ({ target }) => { console.log(target.value, target.valueAsNumber); buildChangesTable(target.value); }; if (!formFooterAdded) buildFormFooter(); }; // Add footer with Package Name input and Create Package button const buildFormFooter = () => { const button = document.createElement('button'); const packageNameInput = document.createElement('input'); const submitDiv = document.createElement('div'); styleMe(submitDiv, { padding: '16px', display: 'flex' }); styleMe(packageNameInput, { width: '220px', padding: '0.3em 0.3em 0.3em 0.5em', flexGrow: 1, marginRight: '16px', background: '#e7e7e7', color: '#000', marginRight: '16px', letterSpacing: '.1em', fontSize: '1.5em' }); button.innerText = 'Create Package'; button.classList.add('aras-button', 'aras-button_primary'); styleMe(button, { padding: '.6em', borderRadius: '.25em', width: 'auto', background: '#000' }); button.onclick = () => { // Get checkbox values const checked = Array.from(document.querySelector('.aras-dialog__content').querySelectorAll('input[type="checkbox"]:checked')).map(x => x.id); // Get Package (to create) name const name = packageNameInput.value; // Create package alert(`Put these:\n${checked.join('\n')}\nin package\n${name}\n`); /* FIXME: The following doesn't error, but it also doesn't actually create a PackageDefinition...? const newPackage = inn.newItem('PackageDefinition'); newPackage.setAttribute('name', name); const result = newPackage.apply(); */ // LOGS, "More than one item": console.log(result.getAttribute('id')); }; // aras-button aras-button_primary packageNameInput.id = 'package-name'; packageNameInput.name = 'package-name'; submitDiv.id = 'modified-since-package'; // submitDiv.appendChild(packageNameInput) submitDiv.appendChild(button); contentDOM.appendChild(submitDiv); formFooterAdded = true; }; // Seems necessary. setTimeout(() => { buildDateInput(); dialogDOM = document.querySelector('.aras-dialog'); styleMe(dialogDOM, { height: 'auto'}); contentDOM = document.querySelector('.aras-dialog__content'); contentDOM.appendChild(dateInputDiv); dateInputDOM = document.querySelector('#modified-since-date-input'); dateInputDOM.onchange = ({ target }) => { buildChangesTable(target.value); }; }, 100); Anwyway, the above results in a list with checkboxes and an input for package name, and all of that is collected and so badly wants to be a package, but I can't seem to even create the package that I want to add all these things to. Ideas? ...but, you just get an alert that tells me that I want to make a package with this stuff. I don't get an error when trying to create a PackageDefinition, but it apparently isn't created. Next steps: Actually create PackageDefinition Add selections to the new package (using id?)1.6KViews0likes0CommentsCreating export packages "PackageElement... Already exists"
I'm creating a demo environment and want to export the new Part definitions and Forms that I have created. When I try to add Part or Form to my new package, I get Unable to add item Form PackageElement (PackageElement) with Element Id '47573682FB7549F59ADECD4BFE04F1DE' already exists. Both part and form already exist in com.aras.innovator.solution.PLM, which I would have expected to use in the "Depends on" section. I can use this PLM package and remove all the other item types and then export, but it would be more convenient to just use my custom package. This seems to be possible as seen in the packages for the aras training here. This includes what I want and more: How do I achieve this? Follow-on question: is it possible to filter what is exported? For example to only export members a certain part classification? Thank you!7.6KViews0likes5CommentsExport/Import custom created menu buttons
Hello, I'm trying to experiment a bit with the import/export tool of the Aras and I'm having a problem with custom menu items. As the custom menu buttons were created inside the Administration/Configuration/Client Presentation/Javascript - Global, they're located by default inside the com.aras.innovator.cui_default package. After I effectuate the export process for this, which executes without any warning/error message and after I'm doing the import to a different Aras Innovator, the main menu (w File, Edit, Views, etc.) is hidden and my custom buttons are not appearing inside the Javascript - Global. The import/export is working well for other items/methods. Can you suggest me a solution for this problem, please? Thank you! Chris14KViews0likes7CommentsExport Error
Hello, I am trying to export a package. I get the following error: faultstring: RelationshipType with name=”ItemType_xPropertyDefinition” is not found. faultdetail: RelationshipType with name=”ItemType_xPropertyDefinition” is not found. faultcode: -1 How can I further analyze this error? regards, Carsten.3.4KViews0likes1CommentLogin error on the PackageImport/Export utility
Hi, So recently I installed Innovator V12, after having uninstalled V11. Everything works fine, except when I try to use the PackageImport/Export utility. It gives me the following Error: Login errors ****ErrorMessage**** faultstring: Failed login to Innovator; original error: <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault> <faultcode>999</faultcode> <faultstring>System.Net.WebException: The remote server returned an error: (401) Unauthorized.</faultstring> <faultactor>HttpServerConnection</faultactor> <detail>unknown error</detail> </SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope> faultdetail:Failed login to Innovator; original error: <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault> <faultcode>999</faultcode> <faultstring>System.Net.WebException: The remote server returned an error: (401) Unauthorized.</faultstring> <faultactor>HttpServerConnection</faultactor> <detail>unknown error</detail> </SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope> Unable to login. faultcode: -100 ******************* I have tried to login with the same credentials in the Webbrowser and it worked. I'm a bit running out of ideas on what to try next to make the utility work. Has anyone encountered the same issue? Kind Regards, Matthias11KViews0likes6Comments
