7 years agoAccelerator III
Export/Import custom created menu buttons
I'm trying to experiment a bit with the import/export tool of the Aras and I'm having a problem with custom menu items.
As the custom menu buttons were created inside the Administration/Configuration/Client Presentation/Javascript - Global, they're located by default inside the com.aras.innovator.cui_default package.
After I effectuate the export process for this, which executes without any warning/error message and after I'm doing the import to a different Aras Innovator, the main menu (w File, Edit, Views, etc.) is hidden and my custom buttons are not appearing inside the Javascript - Global.
The import/export is working well for other items/methods.
Can you suggest me a solution for this problem, please?
Thank you!
