harald_korneliussen_vard_com's avatar
1 year ago
UI doesn't load for one user - anyone had a similar problem?
On our test server, on one particular database, one particular user doesn't get an UI when logging in. I've tried digging into the frontend calls, and it seems it's this call:
https://{our test server}/Server/MetaData.asmx/GetConfigurableUi?accept=json&database={one particular db}&date=2025-05-02T13%3A01%3A58.94&item_classification=%25all_grouped_by_classification%25&item_type_id=&lang=en&location_name=TOC&user={me}
which fails, with a "not a single item" fault. I am in fact logged in, and can e.g. go see the session information on the user button. Deleting all client side caches or logging in with incognito mode makes no difference.
Have anyone else experienced this?
    • No, it isn't that. The login token wouldn't be stored in incognito mode. And I do get logged in, I have a very partial UI, e.g. the user button in the upper right corner, which works as expected.
        It´s not about the token, but the wrong link that people use. And reset the users preferences inside Innovator.
