Suhas's avatar
Suhas
Creator III
internal method
what is the difference between internal method and server side method?
How Aras is compiled it it? How to check code which is present in Internal method?
How developer will create internal method?
Regards,
Suhas
  • According to my research, it seems that Aras does not support developers in creating internal methods directly.
    When creating a DLL, it is required to implement the IInternalMethod interface. However, currently, the IInternalMethod interface is not publicly accessible.
  • Suhas's avatar
    Suhas
    Creator III
    Hello eli_donahue​/ angela​/ asebastian​ ,
    I tried to created a custom method & set method type internal. I have created dll & trying to call this dll method from newly created custom internal method, it is compiling successfully but getting error while execution Class is not Register. How to register this newly created dll Class? I did the reverse engineering & it is coming from Aras core dll.
    Regards,
    Suhas
  • Maybe you can use the same approach that Aras uses to deactivate the upgrade notifications?
    https://docs.aras.com/disabling-notifications/0000019f-d661-d08f-a1df-df61d3510000
