lucas's avatar
lucas
export for existing items
hello,
i have been diving into packaging and exports lately but there is something i can't figure out. it might seem easy but it's not said clearly anywhere i looked.
So, let say i customize an already existing item like Parts,  i had actions, modify the forms and i want to export my work
the next step i need to follow are:
1)since itemType Part is in package "com.aras.innovator.solution.PLM" i had to this package the actions, methods, forms and all items that i could have added to the part item types.
2)then using the aras export tool i can either export the whole package or only  the things i just added to the package.
please tell me if i'm right wrong or if i'm lacking some part.
thanks,
lucas
  • Hello,
    Using the export tool you should be able to export things based on the selections you make prior to creating your package. You can choose everything or only a single element if that is what you want.
    Hope this helps.
    • lucas's avatar
      lucas
      thanks so no need to deal with packages if i'm modifying existing items and want to exports those mods
      lucas
      • Morgan's avatar
        Morgan
        Creator III
        You will still have to place everything into a package using the default tools, however when selecting to export, you can choose which elements within the package to export.
        An alternative, and what I have been using, is Innovator Admin github.com/.../InnovatorAdmin
        With this tool, you can locate specific elements and export them without a package defined.
