Microsoft Power BI Part I: Getting Started
Do you want to interactively visualize and analyze your data inside of Aras Innovator? In this article, I will review the steps needed to create Microsoft Power BI reports and describe how to embed them into an Aras form. 1. Setting Up Power BI ...500Views0likes0CommentsMulti-select Item Actions in Aras Innovator
Actions are one of the most common ways users interact with data in Aras, whether from the main grid, item forms, or main menu. While creating custom actions is fairly straightforward, creating multi-select item actions requires the use of a built-in...500Views0likes0CommentsCustomizing Your Aras Forms: Part 2
As we covered in the first part of our blog series, the possibilities for your Aras forms extend beyond the configuration options in the Aras Form Editor. In this article, we'll see how we can combine a little CSS and Javascript to apply custom ...399Views0likes0CommentsAras Best Practices: Community Projects, Part 2
This post outlines some pitfalls to avoid when creating your Aras Community Project. If you missed our post Aras Best Practices: Community Projects, Part 1, be sure to check it out for even more helpful tips for project authors. Do Not: Use applySQL(...200Views0likes0CommentsCustomizing the Aras Method Editor Theme
If you've ever wanted to change the theme of the Aras Method Editor, this is the post for you! With the following quick and easy tweak, you can change the colors and fonts used to display method code in the editor. Six different themes in the Ar...99Views0likes0Comments
