And here it is: Fresh out of the oven and still warm and crispy -> Innovator 19!
I don´t think the bug was fixed. But hope dies last.
I at least make some progress with understanding tab controls due to requirements of another project. So I think I am close to a patch. Cannot believe this post runs for 8 months already,
Was anyone able to test if the bug still exists in Innovator 21/20?
To my current knowledge, the following Innovator versions are affected by the bug:
Innovator 21
Innovator 20
Innovator 19
Innovator 18
Innovator 17
Innovator 16
Innovator 15
Innovator 14
Innovator 14 Beta
Innovator 12 SP18
Innovator 12 SP17
Innovator 12 SP16
Innovator 12 SP15
Innovator 12 SP14
Innovator 12 SP12 (likely)(There are no "13" versions cause Aras is a little bit superstitious. The New England region is known not only for the large number of PLM vendors, but also for its rich history of...witch trials.)
I assume the bug first appeared in 12SP12 because of a "fixed issue". See release notes:
"Improved synchronization within the user's client session, so that commands such as Edit, Claim, Save, and Done accurately update the item's edit state (like claim and edit icons) across every place that item is displayed in the current session."The improvement is useful, but Aras has overimproved it, which created the current bug.
I still welcome every helping hand so we get a bug fix for this in any of the next releases. Approaches with voodoo, necromancy or recipes for magical incense mixtures to cleanse the server room of bad energies are expressly welcomed! [emoticon:c28b2e4cc20f4ba28d1befdba6bed29c]
Hi community,
since a few minutes you can add Innovator 22 to the above list. I am not too disappointed, cause this version contains the TechDoc Import. But of course the bug still makes this version dangerous as soon as you use anything revised. But if you use TechDocs and like Dashboard, I would definitely recommend to test this one out!
Maybe we should bet on when Aras will fix this problem. My bet: Innovator 29 in March.
