hanwen
5 months agoIdeator I
I use two schemes:
1) Use the name of the object in the PowerPoint slide (usually generated by the system, such as the name of the text box object, which you can modify) to record the bound field name, and then use code to fill or update this value
2) Use the field name bound to the object's web link record, and then use code to populate or update this value
