Simón_Tobon's avatar
Simón_Tobon
12 months ago
Direct Link to Download File From Vault
I am wondering if there is a way to download a file directly via a link. In previous versions of Innovator there was a way to do this through the vault server:   /vault/vaultserver.aspx?dbName={dbName}&fileId={fileId}&fileName={filename}&vaultId={vaultId}
However it seems like in later versions of Innovator this no longer works. I am aware of an option of: /client/?StartItem=File:{fileId}, however this requires a user to authenticate and a popup window is displayed, it is not a direct download.
Is there any way to achieve this?
  • Hi Simon,
    it should work, but the feature is deactivated by default due to security reasons.
    By default users can only access certain data if the have a valid token. This is especially important for public hosted Innovators as you don´t want strangers to access your data just because they have the correct link.
    Check out the guidelines (the one with the File handling when I remember it correct). You have to modify one of the config files to allow direct file access without token.
