2 years agoCatalyst II
Hi Simon,
it should work, but the feature is deactivated by default due to security reasons.
By default users can only access certain data if the have a valid token. This is especially important for public hosted Innovators as you don´t want strangers to access your data just because they have the correct link.
Check out the guidelines (the one with the File handling when I remember it correct). You have to modify one of the config files to allow direct file access without token.
