Release 36 Bug Fix: Search Grids Remain Blank and Strange Horizontal Scroll Behaviour
Hello Innovators, In Release 36 we were facing some strange behaviour: Some grids remaining blank even though items where returned from the search query Horizontal scrolling on grids would result in columns being mixed and glitching After some debugging, we found the issue was caused by 3 files. Attached you find those fixed files and a readme.txt on how to implement them. [View:/community/cfs-file/__key/communityserver-discussions-components-files/10/R36-Blank-Search-Grid-_2B00_-Horziontal-Scroll-Bug-Fix.zip:320:240] I hope this can help anyone else facing this issue. All the best, Daan256Views2likes7CommentsHow can I choose a specific Search Mode when opening a Search Dialog via Method?
Hi community, I use following code to open a classic Part search dialog. [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:e11e18e7-06f2-4dd3-8697-899cd4f649c4:type=javascript&text=const%20param%20%3D%20%7B%0A%20%20%20%20aras%3A%20aras%2C%20%0A%20%20%20%20type%3A%20%27SearchDialog%27%2C%0A%20%20%20%20dialogWidth%3A%201200%2C%0A%09dialogHeight%3A%20500%2C%0A%20%20%20%20itemtypeName%3A%20%27Part%27%2C%20%20%0A%20%20%20%20defaultSearchMode%3A%20%22AML%22%2C%20%20%2F%2F%20%3F%3F%3F%3F%3F%3F%0A%7D%3B%0A%0Aconst%20topWnd%20%3D%20aras.getMostTopWindowWithAras%28%29%3B%0AtopWnd.ArasModules.MaximazableDialog.show%28%27iframe%27%2C%20param%29.promise.then%28callback%29%3B] Is it possible to pre-select the used search mode? Typically the "Simple" (Einfach) search mode is preselected. I have an additional custom search mode that is similar to Simple, but allows users to search for all generations of a Part. In my use case user shall be able to search and select previous Part versions. So it would be convenient if my custom search mode would be selected automatically when the search dialog is opened. I guess this is currently not possible. But maybe somebody has an idea? Thanks! Angela282Views0likes5CommentsMaking 'Simple' search default in relationship tabs instead of 'Hidden'
Innovator seems to remember search filter criteria that has been previously used in Simple search on relationship tabs. This makes it cumbersome for users to know if they are really seeing the right data in a relationship tab which loads by default with the search criteria in 'Hidden' form. The user needs to change search mode to Simple and then only will they be sure there is no filter criteria there. Is there a way to default the search mode in all relationship tabs to 'Simple' to make this clear and obvious for users? Alternatively, is there a way to prevent Innovator from remembering search filter criteria on a newly loaded relationship tab?Solved270Views0likes2CommentsAras search grid edit OOTB issue
Hello Team, I have observed that when I try to check a Boolean property value as true from the main search grid window, it does not update correctly. On the server side, we are receiving the value as true instead of 1 . Is there any workaround for this? angela ,eli_donahue , asebastian Regards, Suhas126Views0likes12CommentsCustomize labels of search grid by classification
Preparing several forms for an ItemType by classification can change those labels on the same property. But can I do that on search grid too? For example, apply a client method to watch the search criteria of classification and switch the label.108Views0likes2CommentsSave User choices or Create Default list in Refine button CUI
When clicking the refine button : a list is presented : with already checked values corresponding to the columns (properties) of the presented ItemType. The method responsible of the Init of the button is : cui_common_refine_init Code : Toolbar.extendFormatters({ refine: columnSelectionMediator.cuiToolbarFormatter.bind(columnSelectionMediator) }); return { type: 'refine' }; I would like to know if it's possible to personalize these filters on the search by code or configuration, or associated to user preferences, or saving when checked/unchecked by User ? Everything is already checked and some users would like to be able to have a "default" view. Thanks74Views0likes1CommentJavascript method to set the default value in search grid?
We need to limit the search results of "Document" item for certain identity. The default value of "Classification" should be prefilled to "General" and should be unchangeable by the user. I was thinking if I can get the current identity of the user and then call a function that would prefill the "Classification" to "General" and make it uneditable. I have a code for finding the identity of the user. I need to know how to target the "Classification" field of "Document" item type in the search grid view thanks!121Views0likes2CommentsOpening Aras Part Search on a new Aras Tab through an HTML page
Hello everyone! I am trying to create a custom HTML page which links to other Aras pages such as the Part Search Grid. My issue is including a script in the HTML page that links to an Item Type. I have been guided towards using the method cui_ivicb_nav_search_click, however I am unsure how to implement this with an HTML page. Could you suggest me some possible solutions for this? Kind regards, WishalSolved112Views0likes2CommentsPrefill simple search criteria in the search grid
Hello, For Documents item type, in the search grid I need the "Classification" to be prefilled to "General" . I applied client side method to "classification" and "search_default" properties of Documents but it doesn't work. "search_default" property did not exist before so I just added it, I don't know if that makes a difference. method: return {classification:{filterValue:"General",isFilterFixed:false}};Solved209Views0likes8CommentsNeed server method to hide property of an Item for specific identity
As the tilte says. We want the "Classification" property of ItemType "Document" to be hidden for a user if they are part of a specific identity. I also want the value of "Classification" to set as "General" for these users when they search of Documents. I have achieved this. However, now we do not want the users of this identity to be able to see the "Classification" column in the search grid. How do I accomplish this. I apply the code below to "onBeforeGet". Mentioned below is my method: Innovator inn = this.getInnovator(); //Get ID of the logged in user Item alias = inn.newItem("Alias","get"); alias.setProperty("source_id",inn.getUserID()); alias.setAttribute("select","related_id"); alias = alias.apply(); string relatedId = alias.getProperty("related_id"); int count = alias.getItemCount(); string target = "DBA5D86402BF43D5976854B8B48FCDD1"; if(relatedId == target){ this.setProperty("classification", "General"); this.createRelationship("Property", "edit"); this.setProperty("id", "DE3C90BC7B434151A6F3C9D97A5B2B69"); // Property ID this.setProperty("is_hidden", "1"); // Hide the property this.setProperty("is_hidden2", "1"); // Hide the secondary property } return this;88Views0likes1Comment
