- DuncanwilliamgibbonsIdeator I
Im stuck on the aras innovator installer now, when i click configure database i get an error:
[Microsoft][ODBC SQL Server Driver][SQL Server] Login failed for user 'innovator'
- asebastianNew Member
Are you following the Installation guide which was packaged with the CD Image? Could you post a screenshot of the Installer before you press configure database?
Got it working by doing a fresh install, was probably an error with one of the password. thanks all for the help
Hi Duncan,
It looks like you can install IIS on windows 10 home, take a look at this StackEchange post : https://superuser.com/questions/1245472/does-windows-10-home-edition-have-iis.
As far as a database is concerned, Jukka is correct. You can download the free version of MSSQL and connect your innovator instance to that.
AJ
Thanks ill try that and get back to you
- jukkatlehtinenIdeator I
Aras is IIS application, so it needs Windows + IIS + SQL to run. BUT if you have Windows laptop, you usually can install IIS on that + free SQL Express (DB). So you don't need 'server' for that.
I'm not 100% sure which Windows versions support installing IIS (student?, home?, pro -yes).
Or are you using mac?
//Jukka
- Former Member
I am trying to install ARAS on WIN 10 home, anyone succeeded yet??? i am using SQL EXPRESS , facing error W3SVC
- GopikrishnanIdeator I
What is the error message ?
I have windows 10 home
