Hi Alexandrecimp,
Just to make sure I understand, in this table the IS_CURRENT column is a 1 when it's the most recent version and a 0 if it's old? If that's the circumstance, and you want the objects which have the state Working and are current, then it seems like rows 1 and 2 are the correct output, since row 4 isn't current.
You can effectively do OR searches, but since line 3 has IS_CURRENT of 1, it would turn up in that search. In this data set, just searching for (state='working') would return only rows 1, 2, and 4, but I imagine that in a larger data set there might be rows which are being worked on but aren't current.
Let me know if that helps! If it doesn't, please give a little more detail on what defines the most recent rows. If there isn't a clear answer in the data you have, you might be able to add a property that would have the information you need.
Skyler C.
Thank you very much for your reply !! It is very valuable.
- Former Member6 years agoNot applicable
I agree with you, it was a really useful answer, thank you. jack
