8 years agoAccelerator III
Error during database setup and admin login
I've followed the YouTube installation videos and installation guide PDFs to the letter several times, but it seems I can not get past an error.
When I click "configure database" during Aras Innovator installation, after about a minute or two of what seems to be useful work, I get an error message that says: "Error 27506. Error executing SQL script CoreAndSolutions.sql. Line 136543. Must declare the scalar variable "@EXISTING_ID". (137)"
I then hit OK and the "database installation process" stops without any further errors. At this point I don't know whether the installer attempted to continue to do other stuff or just gave up after the above error.
I then click "Next" in the installer and continue Aras installation. There are no further errors and the installation is completed.
I then go to: localhost/.../ and the login screen pops up. I enter "admin" as username and "innovator" as password, but I get the following message and can not proceed further: "Invalid column name 'id'."
I started SQL management studio to check the DB, and the "InnovatorSolutions" db appears to be in there. Owner is "sa", size is 62.75MBi Number of users 6, Collation: Turkish_CI_AS
This is a Windows 7, 64-bit system. SQL server is SQL Express 2014. Aras innovator is the latest innovator as of June 2018. We tried the entire installation process 3 times to no avail.
We'd appreciate any help with this issue.
