Hi Salini,
The password grant authentication option was deprecated in R14, so you’ll need to update your application to use the OAuth 2.0 login flow.
Here’s a blog post demonstrating how to get an access token via Postman: https://aras.com/en/blog/authenticating-in-oauth-2-0-with-aras-restful-api
And here’s a sample console application that shows how to authenticate with an access token via .NET Core: https://github.com/ArasLabs/rest-auth-example
Hai Eli Donahue,
Thanks for the response, I have tried as mentioned, I have generated access token successfully,
but I could not find the odata/Part in my server. After that I could not proceed.
any thought on this?
Thanks in advance
Salini
- eli_donahue2 years agoCommunity Manager
Hi Salini,
What happened when you sent the request? Did you get an error message or did the server return “no items of type Part found”?
- salini_sivasubramanian1 year agoCreator I
Hai ,
I can able to generate the access token successfully , But the parts are always empty array .I have tried with the BRUNO , even though the parts returns as empty array.
And also we are using a .NET framework console application . Could this be a problem .
I have tried to create a .CORE application to populate the parts but the await method exit the application automatically .
Can you help me with this please ?
Thanks in advance .
Regards
Salini V
Hai Eli Donahue,
I have fixed the issue
I have added the ODATA services into the nnovatorServerConfig.xml<Service Enabled="true">
<Name>OData</Name>
<Route>/server/odata</Route>
<Handler>Aras.Server.OData.ODataHandler, Aras.Server.OData</Handler>
</Service>
and added the line <Scopes>Innovator OData</Scopes> into the oauth.config file.
And restarted the server.
Now I can able to access the parts , Thank you for your guidance through out the conversation . It was very helpful .
Regards
Salini
