Morgan's avatar
Morgan
Creator III
4 years ago
When exposing the affected items tab on express eco I get TypeError: Cannot create property 'width' on string 'image'
Any ideas on how to resolve this? It doesn't seem to affect anything other than UI response after it appears but it is quite an annoyance to anyone that clicks on the tab. I am trying to display some properties for review.
  • Hi,
    I have seen this bug too in various scenarios. It depends a little bit on your Innovator version and the planet rotation of the universe (=the error message sometimes appears for no reason).
    In the Affected Items tab you have one column that should display an item icon. Do you see the icon? I am pretty sure this property is the source of this error message. In my case hide/unhide the property fixed the error....(yes, I wished I would know a better solution)
    • Morgan's avatar
      Morgan
      Creator III
      Thanks for the reply. I think it is happening for no reason unfortunately as I have tried hiding and re-enabling all the available columns I want displayed and the error presents no matter what. I wonder if this is a unique situation as I am using an affected item relationship elsewhere and do not see this same issue. I will have to dig deeper as the only place I can see potential issue is the relationship item itself.
        You can check what happens when you disable the Method 'PE_PopulateAffectedType'. This one populated the image.
