Thanks for the reply. I think it is happening for no reason unfortunately as I have tried hiding and re-enabling all the available columns I want displayed and the error presents no matter what. I wonder if this is a unique situation as I am using an affected item relationship elsewhere and do not see this same issue. I will have to dig deeper as the only place I can see potential issue is the relationship item itself.
You can check what happens when you disable the Method 'PE_PopulateAffectedType'. This one populated the image.
- Morgan4 years agoCreator III
Thanks for the tip, it produced the same result.
I wished I would know the root-case for this one, but right now I only know solutions based on Voodoo and karma.
I remember in one case the error message was related to a foreign property where I linked a thumbnail. I removed the property completely and then added it again --> problem solved.
In another case I had to re-add poly-sources in a PolyItem type.
The bug first appeared in Innovator 12SP18 in my case. Never have seen it in previous versions.
Ah thanks for this. I will give this a try. I have added some foreign properties and a few months ago we also updated to SP18.
