Joshua_Bowden's avatar
Joshua_Bowden
4 years ago
Send emails from a C# Method not working
I am trying to send an email from within a C# method but I am not receiving the message in my email. My code is made up of trying to check a url and then return if the url returned with an OK status or a 404 Error. When I get to the part where I want to send the email to myself it runs the code but I do not receive the message. Below is a snippet of my code. The result boolean value is returning true. Any idea what could be wrong?
Item fromUser = this.newItem("User", "get");
fromUser.setProperty("login_name", "admin");
fromUser = fromUser.apply();
//Get email message
Item email_msg = this.newItem("EMail Message", "get");
email_msg.setProperty("name", "ARAS Job Scheduler");
email_msg = email_msg.apply();
email_msg.setProperty("subject", "Series Website Check " + DateTime.Now.ToString());
email_msg.setProperty("body_plain", messageBody);
email_msg.setPropertyItem("from_user", fromUser);
//Get admin Identity
Item iden = this.newItem("Identity", "get");
iden.setProperty("name", "Joshua Bowden");
iden = iden.apply();
//return inn.newError(email_msg.ToString());
bool result = this.email(email_msg, iden);
  • 1. Does your User item contain the required email address?
    A: My user has the correct company email address.
    2. Do you have checked your Spam folder?
    A: Nothing in there.
    3. Does your Email Message items contains the correct "From User"?
    A: We are using the default Innovator Admin user.
    ***Solution***
    I switched the "From User" to myself and I was able to receive the email. I am assuming that it was not working because the Innovator Admin user did not have an email registered to it.
  • Also, I am planning on running this through the Job Scheduler so to test this method I am using the "Run Server Method" Action.
      Have you ever sent any emails from your Innovator at all, e.g. via LifeCycle messages?
      Have you specified your email service in the server config files?
      It´s not surprising your code returns a 'true' result. But with the default settings, your emails just will end up as text files in the temp folder in your codetree.
      • Joshua_Bowden's avatar
        Joshua_Bowden
        We are not incorporating Lifecycles in our current system due to issues we had in the past with them but I have used the email notification on a workflow which works perfectly fine sending me an email. I also checked the server config files and everything seems to match what was discussed in other threads. I read in another thread that it might go to the Innovator/Server/temp folder but I do not see the text files in there either.
