eli_donahue
8 years agoCommunity Manager
Hi kvaskrishna,
If you only want to see active activities in the InBasket, you can filter the grid results on the status field. Otherwise, I believe the behavior you are seeing is expected. You are voting on an active activity. When the vote completes, the activity is closed and the next activity becomes active.
Eli
