Auto vote workflow task when timeout
Hello, I’ve created a very simple workflow with three statuses: Submit, Approval and Released In the Approval status, there are eight review and approval assignments, and I need any that haven’t been completed within five days to be automatically voted as ‘Approve’. I’ve been looking into this, but the only information I’ve found is very old and refers to a VB method. Is there an easier way, or would I need to create a method in On Escalate? Thanks141Views0likes1CommentDynamically Add Workflow Process Path
Hi Community, Just wondering if this error is common. Basically I have a workflow with multiple activities in sequence. I also have another activity that is not in the sequence and has no paths to it (we'll call this activity X). I am looking to, via an action, create a workflow process path to activity X and then vote that path. I am getting an insufficient permission error to add a workflow process path. Am I missing something here? Can Add for that item type shows admin has rights. Is there another item I need to take into account?3KViews0likes5CommentsWorkflow Process Get Change ItemType
Good day all. I have a Method to dynamically assign a drafter to the activity. Currently I have to specify the ItemType of the change I am using for this method to work, meaning I would have to recreate the Method for each different kind of change ItemType I want to use this on. How can I pull the associated change ItemType from the Workflow Process or Workflow Process Activity that the method is running from to make this a more generic method? The Method is written in C#. Thank you for your help.Solved4.3KViews0likes3CommentsAuto Workflow Assignment - Defined Identity in ECR Item
I have reviewed the 'Auto Workflow Assignment' lab. I wish to model the following scenario: 1. Add a mandatory 'ECR Coordinator' property to the ECR ItemType and ECR Form. The ECR creator selects the User that will coordinate the processing of the ECR. (Done) 2. Create a new ECR 'Workflow Map' that has the assignment of 'ECR Coordinator' at certain Activities. The 'ECR Coordinator' is an Identity with no members. (Done) 3. Create a new ECR, and the following occurs. (to be Done) 3.1 The OnActivate method determines the 'Get Controlled Item'. 3.2 The relationships are expanded from the 'Controlled Item' to find all the activities that have the 'ECR Coordinator' identity assigned. Workflow Process -> Workflow Process Activity -> Activity -> Activity Assignment -> Identity 3.3 For each 'Activity Assignment' relationship that has the 'ECR Coordinator' identity assigned either (a) Change the related_id from 'ECR Coordinator' to the user assigned as the ECR Coordinator from the ECR item or (b) Create a new 'Activity Assignment' relationship between the Activity and the 'ECR Coordinator' user. Then delete the existing 'Activity Assignment' relationship that has the related_id of 'ECR Coordinator'. 4. The Workflow Process continues, with the 'ECR Coordinator' being given tasks, and email notifications.5KViews0likes2CommentsWorkflow and Lifecycle - restricting manual promotion of life cycle states.
Hi I have a workflow and lifecye defined for an item type. Say if the current workflow task is "start" - my life cycle of the item is promoted from "Draft" to "Active". However before voting the user is able to manually promote the lifecycle from draft to active. Is there any way to restrict the manual promotion of the item when workflow is involved. Any help would be greatly appreciated, thanks. [emoticon:c4563cd7d5574777a71c318021cbbcc8]Solved5.9KViews0likes1CommentSee when and who claimed an activity
Hi We try to use as much as the out of box functionality as possible. We have just released a part request process in Aras and in this process we use the Claim functionality in "My InBasket". It works as supposed, but now users are asking if we can make it possible to see on the itemttype who has claimed the activity and when it was claimed by that person? Is that possible and if so how? Perhaps add to the infobox in the top left corner where Created By, Locked By, and etc is shown. Best Regards Henrik Olesen Kamstrup A/SDenmark2.8KViews0likes2CommentsMultiple workflow tasks entries getting created?
https://drive.google.com/open?id=1GTZtasDNfS3FzN3WPgSvMQ9W-8atlCvf above link for workflow task activity Hi, Workflow task status is getting changed with multiple entries in MyInnovator>InBasket some times in a single entry the status is getting changed for all the completion of tasks. Actually in a single entry the status should be changed based on the task completion. this is the correct way. but multiple entries are getting created. This problem is happening and not for sometimes. Kindly click the link and look into the video to notice the problem and provide the way.2.6KViews0likes1Comment
