Nathan_H_'s avatar
Nathan_H_
Accelerator I
4 years ago
Change Field Set to Workflow Activity
Good day all.  Has an anyone set a method to add the current workflow activity name to a change field?  We reference the changes more by the workflow activity than we do by the change state.  Thanks for your help with this.
  • I guess I should have come back to this and post the C# method I use.  I have this assigned to the Activities of the Workflow Template with an On Activate event.
    [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:9cde3055-6429-4da1-990b-055ed4c4c546:type=text&text=%2F%2F%20Called%20OnActivate%20from%20activities%20in%20a%20change%20workflow.%20%20Gets%20the%20Activity%20name%20and%20assigns%20it%20to%20the%20sm_workflow_activity%20field%0A%2F%2F%20Works%20as%20of%2030%20June%202023%20%20NDH%0A%0AInnovator%20inn%20%3D%20this.getInnovator%28%29%3B%0Astring%20actId%20%3D%20this.getID%28%29%3B%20%20%2F%2F%20GET%20current%20Activity%20ID%0A%0A%2F%2F%20Added%20for%20Method%20identification%20associated%20to%20error%20message%20%2027%20September%202022%20%20NDH%0Astring%20methodName%20%3D%20%22%5Cr%5Cn%20Method%3A%20%20sm_Get_Activity_Name%22%3B%0A%0A%2F%2F%20GET%20workflow%20item%0AItem%20wflItem%20%3D%20this.newItem%28%22Workflow%22%2C%22get%22%29%3B%0A%20%20%20%20wflItem.setAttribute%28%22select%22%2C%22source_id%2Csource_type%22%29%3B%0A%20%20%20%20%0AItem%20wflProc%20%3D%20wflItem.createRelatedItem%28%22Workflow%20Process%22%2C%22get%22%29%3B%0A%20%20%20%20wflProc.setAttribute%28%22select%22%2C%22name%22%29%3B%0A%0AItem%20wflProcAct%20%3D%20wflProc.createRelationship%28%22Workflow%20Process%20Activity%22%2C%22get%22%29%3B%0A%20%20%20%20wflProcAct.setAttribute%28%22select%22%2C%22related_id%2Cname%22%29%3B%0A%20%20%20%20wflProcAct.setProperty%28%22related_id%22%2Cthis.getID%28%29%29%3B%0A%20%20%20%20wflItem%20%3D%20wflItem.apply%28%29%3B%0A%0A%2F%2F%20VERIFY%20that%20the%20Workflow%20has%20been%20retrieved%0Aif%20%28wflItem.getItemCount%28%29%20%21%3D%201%20%7C%7C%20wflItem.getProperty%28%22source_id%22%2C%22%22%29.Length%20%21%3D%2032%20%7C%7C%20wflItem.getPropertyAttribute%28%22source_type%22%2C%22keyed_name%22%2C%22%22%29.Length%20%3C%201%29%0A%7B%0A%20%20%20%20return%20inn.newError%28%22Error%20retrieving%20workflow%3A%20%22%20%2B%20wflItem.getErrorDetail%28%29%20%2B%20methodName%29%3B%0A%7D%0A%0A%2F%2F%20GET%20ItemType%20of%20the%20change%20using%20the%20Method%20-%20labs_GetControlledItemCSharp%0AItem%20controlledItem%20%3D%20this.newItem%28this.getAttribute%28%22type%22%29%2C%20%22labs_GetControlledItemCSharp%22%29%3B%20%0A%20%20%20%20controlledItem.setID%28this.getID%28%29%29%3B%20%0A%20%20%20%20controlledItem%20%3D%20controlledItem.apply%28%29%3B%0A%0AItem%20wflActivity%20%3D%20this.newItem%28%22Activity%22%2C%22get%22%29%3B%0A%20%20%20%20wflActivity.setAttribute%28%22select%22%2C%22name%22%29%3B%0A%20%20%20%20wflActivity.setID%28wflProcAct.getProperty%28%22related_id%22%29%29%3B%0A%20%20%20%20wflActivity%20%3D%20wflActivity.apply%28%29%3B%0A%0Astring%20cmType%20%3D%20controlledItem.getAttribute%28%22type%22%29%3B%0Astring%20activityName%20%3D%20%22%22%3B%0A%0Aswitch%28wflActivity.getProperty%28%22name%22%29%29%0A%7B%0A%20%20%20%20case%20%22Close%20Change%22%3A%0A%20%20%20%20case%20%22Close%20ECR%22%3A%0A%20%20%20%20case%20%22End%22%3A%0A%20%20%20%20%20%20%20%20activityName%3D%22Closed%20-%20Completed%22%3B%0A%20%20%20%20%20%20%20%20break%3B%0A%20%20%20%20%0A%20%20%20%20case%20%22Cancel%20Change%22%3A%0A%20%20%20%20case%20%22Cancelled%22%3A%0A%20%20%20%20%20%20%20%20activityName%3D%22Closed%20-%20Cancelled%22%3B%0A%20%20%20%20%20%20%20%20break%3B%0A%20%20%20%20%0A%20%20%20%20default%3A%0A%20%20%20%20%20%20%20%20activityName%3DwflActivity.getProperty%28%22name%22%29%3B%0A%20%20%20%20%20%20%20%20break%3B%0A%7D%0A%0Abool%20permissionWasSet%20%3D%20false%3B%0AAras.Server.Security.Identity%20transIdentity%20%3D%20Aras.Server.Security.Identity.GetByName%28%22Aras%20PLM%22%29%3B%0A%0Atry%0A%7B%0A%20%20%20%20%2F%2F%20permissionWasSet%20%3D%20Aras.Server.Security.Permissions.GrantIdentity%28transIdentity%29%3B%0A%20%20%20%20Aras.Server.Security.Identity%20admin%20%3D%20null%3B%0A%09bool%20permsWasSet%20%3D%20false%3B%0A%09%0A%09admin%20%3D%20Aras.Server.Security.Identity.GetByName%28%22Aras%20PLM%22%29%3B%0A%09permsWasSet%20%3D%20Aras.Server.Security.Permissions.GrantIdentity%28admin%29%3B%0A%20%20%20%20%0A%20%20%20%20%2F%2F%20SET%20the%20Workflow%20Activity%20field%20from%20the%20change%0A%20%20%20%20var%20ecoParent%20%3D%20this.newItem%28cmType%2C%20%22edit%22%29%3B%0A%20%20%20%20%20%20%20%20ecoParent.setID%28wflItem.getProperty%28%22source_id%22%29%29%3B%0A%20%20%20%20%20%20%20%20ecoParent.setProperty%28%22sm_workflow_activity%22%2CactivityName%29%3B%0A%20%20%20%20%20%20%20%20ecoParent%20%3D%20ecoParent.apply%28%29%3B%0A%7D%0A%0Afinally%0A%7B%0A%20%20%20%20if%20%28permissionWasSet%29%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20Aras.Server.Security.Permissions.RevokeIdentity%28transIdentity%29%3B%0A%20%20%20%20%7D%0A%7D%0A%0Areturn%20this%3B%0A%0A%20%20%20%20%2F%2F%20return%20inn.newError%28%22Test%3A%20%22%20%2B%20activityName%29%3B]
  • I think you should switch to automation or other supported solutions.
    vex 6
  • According to what I can see, your running activity is three steps away from the change record: the change record has an associated wf context (this is the running workflow), then from that you can find the wf executing (this is the running activity - be careful here because you could potentially have multiple activities running at the same time), and then from that you get the wf activity (which is the running activity) (the activity in the workflow definition, which is I believe what you want the name of).
    cookie clicker
