jeff_stroh
4 years agoCreator II
Innovator is not defined Client Side Error
I've got a very simple method that creates a new PR from a button on a TGV. This worked perfectly in V12, but is not working in our V15 instance. Any help would be greatly appreciated!
The error message is: The method 'create_PR_from_tgv' failed. Innovator is not defined Client Side Error
The code is below:
var inn = new Innovator();
var pr = inn.newItem("PR","add");
pr.setProperty("parent", thisItem.getID());
top.aras.uiShowItemEx(pr.node, "tab view", true, true);
