Hi Maddy,
You have a couple options. If you don't want the property to be mapped through the office connector, you can delete that relationship from the Document Type in the Office Connector preferences in Innovator. This will leave the property empty when the item is created through the connector.
If you're looking to have a default value, this can be set on the property itself by following the steps below.
- Login as an administrator
- Navigate to TOC > Administration > ItemTypes
- Search for the ItemType that is getting created
- Document would be the default ItemType for the Office Connector
- In the Properties relationship tab, find the desired property
- In the Default Value column, set the value you want this property to default to.
Hi Chris,
Thank you for your quick reply.
I want to set default value for some of the classifications of Document not for all classifications.
So, is it possible to set value while saving document thru Office Connector.
Regards,
Maddy.
- cldavis_smcusa_com2 years agoCreator I
Maddy did you ever get a solution to this? I am looking to do something similar
