- Zahar_ChernovCreator IISearch for admin user, lock it and on left side there is checkbox "Enabled" untick it.
- eli_donahueCommunity ManagerHi Vijay, You can also enable and disable user login via SQL:
Note: Do not disable the vadmin user, or you will encounter issues with vault permission. Eli Aras Labs Software Engineer-- enable login update innovator.[user] set logon_enabled='1' where login_name in ('admin','root') -- disable login update innovator.[user] set logon_enabled='0' where login_name in ('admin','root')
