eli_donahue
9 years agoCommunity Manager
Hi Vijay,
You can also enable and disable user login via SQL:
-- enable login
update innovator.[user] set logon_enabled='1' where login_name in ('admin','root')
-- disable login
update innovator.[user] set logon_enabled='0' where login_name in ('admin','root')
Note: Do not disable the vadmin user, or you will encounter issues with vault permission.
Eli
