Hi Hadrien
You can check below things
1. While exporting the package, check
- Export referenced Item - Unchecked
- Reference to unknown Packages - Remove with Warning
2. Does your item type has any relationship ?. If so, you have to add the relationship also to the package and export.
3. You can remove the client presentation if not required in item type client style tab. Try export and import after that
3. In import tool, the type should be 'Merge'
4. You can check the logs in the import folder. Generally logs will be in the same folder where import.exe is located
Thank You
Gopikrishnan R
Thanks for your answer... But still the problem...
1) It was done like that
2) No I had the problem on a complexe package, but I reproduce the bug with only 1 item + its form
3) I did it's raising the error anyway
3 bis) of course it is...
4) logs are... hum not helping...
5) the support Aras propose to modify the AML with update action instead of add, it does not work and raise the error
What's really bothering me is that I do a package exactly as for 11spX version without problem...
- hadrien_guiducci6 years agoCreator I
Does anyone has see this ?
