Upload file Rest API using Logic App
I am currently developing a sample project in Azure Logic Apps using the Aras Restful APIs. However while trying to Execute the vault.UploadFile API I am facing the 500 error message: The Rest API Call Details are as follows : { "uri": ".../vault.UploadFile?fileId=EB166A9FF4EE47C8A0DA55252CA140CA", "method": "POST", "headers": { "Authorization": "*sanitized*", "Content-Disposition": "attachment;filename*=utf-8''Hello.txt", "Content-Length": "5", "Content-Range": "bytes 0-4/5", "Content-Type": "application/octet-stream", "transactionid": "0c2c787fce70226029d752c0ba372607" }, "body": "Hello" } For now I am trying to upload a simple text file as seen above. I have verified the url as well as run the same in Postman , ARC and fiddler - and I am able to get it working in all the cases except for via Logic Apps . Please let me know if anyone knows what I am missing here . Thanks9.5KViews1like4CommentsUpload File without creating a new generation
I wish to create an Action for the Document ItemType that 1. Prompts the user to select a file, 2. Uploads the file, and 3. Does not create a new generation of the Document Item. Use Case: A Document, for example at Rev C, are reviewed via the out-of-the-box (OOTB) Document Change Object. Prior to the Release step, a PDF file is generated and submitted to the customer. The workflow is then completed, setting the state of the Document as Released. The PDF is sent to the customer for approval. And a new revision, Rev D, of the Document is started using subsequent DCO. Not a problem. The customer returns a wet-ink or digital signed PDF file of the Rev C of the Document. This version of the PDF is to be included in the the latest generation of Rev C, which most probably will have been updated by Rev D and subsequent generations. It is not appropriate to add the signed PDF to Rev D or later iteration. This process is possible using AML, by 1. Determine the ID of the latest generation of Rev C of the document. 2. Using admin, drag and drop the file into the file vault. 3. Get the ID of the file, after it has been uploaded, and 4. Using AML <AML> <Item type='Document File' action='add'> <source_id>id of the document at the correct generation</source_id> <related_id>id of the uploaded file </related_id> </Item> </AML> Can the above sequence be done using an Action, a Form with a File Item field or some other method?6.4KViews0likes6CommentsUpload and download File from vbscript
Last days, i am trying to develop a visual basic script to upload file into vaultserver. I have read previous Post from year 2007, but I have not managed to upload files. Does anyone have a script to upload files using soap? Thanks, Jesús5.2KViews0likes3CommentsHow can I upload blob data to vault in javascript?
I have a blob from the clipboard. Basically It is an image. I put the blob data in an img tag. So I wanna upload the blob data to the vault and use it as an Image property. Is there any idea to upload blob to vault in javascript?Solved4.7KViews0likes2CommentsUploading CADdocs with Relationships from local PC to ARAS
Hi All, looking to create a method to allow me to upload CADdocs into Aras, from my local computer, without needing to use a CAD Connector. I am new to developing for Aras and could use some pointers. Does anyone have any ideas or could lead me down the right path to get something started. I'm envisioning a form where I select the top-level assembly and its children from a folder on my desktop and upload them into Aras. Any help or tips are appreciated!3.3KViews0likes1CommentUpload a file as attachment to document Item
Hi, I would like to know is it possible to load a doc or docx file to aras using data loader. I am using data loader which load the document(Item) from excel file. so is it possible to load the file(attachment) load with the parent Item (in Document File Relationship)i.e. wih Document. Thanks.3KViews0likes2CommentsDoes ARAS server need access to the file for Item.attachPhysicalFile to work?
We are using a cloud version of ARAS, and I am trying to attach a physical CAD file to an item. But I am receiving the exception: Item is not of type 'File'. I have verified the existence of the file, and the path is in UNC format, so I am wondering if the server needs physical access to the file for verification. at Aras.IOM.Item.CheckThatTypeOfItemIsFile() in d:\Builds\Innovator.Builds\6296-Innovator-RELS11-0-SP5\Innovator\CompilableCode\IOM.NET\Item.common.cs:line 5359 at Aras.IOM.Item.attachPhysicalFileInternal(String filePath, String vaultServerId) in d:\Builds\Innovator.Builds\6296-Innovator-RELS11-0-SP5\Innovator\CompilableCode\IOM.NET\Item.common.cs:line 5234 at Aras.IOM.Item.attachPhysicalFile(String filePath) in d:\Builds\Innovator.Builds\6296-Innovator-RELS11-0-SP5\Innovator\CompilableCode\IOM.NET\Item.common.cs:line 5173 at ARASImport.frmImportPLM.UploadPartDocuments(Item part) in c:\code\frmImportPLM.cs:line 15042.6KViews0likes2CommentsUpload Files with AML - does it still work this way?
Hi Community, in many forum posts samples are shown how to upload files via AML. Typical one: <Item type='Document' action='add'> <item_number>uploadtest</item_number> <name>myName</name> <description>myDescription</description> <Relationships> <Item type='Document File' action='add'> <related_id> <Item type='File' action='add'> <actual_filename>c:\temp\uploadtest.txt</actual_filename> <filename>uploadtest.txt</filename> <Relationships> <Item type='Located' action='add'> <related_id>67BBB9204FE84A8981ED8313049BA06C</related_id> </Item> </Relationships> </Item> </related_id> </Item> </Relationships> </Item> I remember that I was able to use this script successfully in the past. But in Innovator 12 it doesn´t seem to work anymore. Does anyone know if we need a different approach now? Thanks and best regards! Angela1.3KViews0likes0CommentsError when try to upload a file ARAS 12
When I try to upload a file in my Item Type, I receive the error Multiple Errors: DoPhysicalFiles - SendRequestToVaultServer: invalid_client -, it was working normally, but today start to show this issue. Someone pass by this issue and can help me? Thanks a lot.399Views0likes4Comments
