ShrutiS's avatar
ShrutiS
Upload file Rest API using Logic App
I am currently developing a sample project in Azure Logic Apps using the Aras Restful APIs.
However while trying to Execute the vault.UploadFile API I am facing the 500 error message:
The Rest API  Call Details are as follows :
    "uri": ".../vault.UploadFile?fileId=EB166A9FF4EE47C8A0DA55252CA140CA",
    "method": "POST",
    "headers": {
        "Authorization": "*sanitized*",
        "Content-Disposition": "attachment;filename*=utf-8''Hello.txt",
        "Content-Length": "5",
        "Content-Range": "bytes 0-4/5",
        "Content-Type": "application/octet-stream",
        "transactionid": "0c2c787fce70226029d752c0ba372607"
    "body": "Hello"
For now I am trying to upload a simple text file as seen above. I have verified the url as well as run the same in Postman , ARC and fiddler - and I am able to get it working in all the cases except for via Logic Apps .
Please let me know if anyone knows what I am missing here . Thanks
  • Hi beginnerInAras,
    When you are sending your POST request are you including an Authorization (BearerToken) token as well? Anytime you are using REST API it is necessary to first send a POST request to the OAuthserver, then grab that token and pass it as authorization with your actual request. We have a good example of this covered in a couple of blog posts.
    Hope this helps!
    Best,
    Nithin
  • Former Member's avatar
    Former Member
    Not applicable
    Although1337x-proxy  is often thought of as a no-code tool, it’s better understood as an alternative to the venerable BizTalk business automation tool. When you build a Logic App, you’re providing basic rules for linking more than one application with a network of components, providing the rules and structure needed for message routing.
    Former Member
    Not applicable
    This post is extremely helpful for me. I really appreciate your kindness in sharing this with me and everyone else!
  • We explored two different ways to handle file uploads in a REST API, MultiPartParser, which can be used to handle a file upload from the web, and FileUploadParser, which can be used to handle raw file uploads.
