Joel-Hwang's avatar
Joel-Hwang
Ideator II
How can I upload blob data to vault in javascript?
I have a blob from the clipboard. Basically It is an image. I put the blob data in an img tag.
So I wanna upload the blob data to the vault and use it as an Image property.
Is there any idea to upload blob to vault in javascript?
    • Joel-Hwang's avatar
      Joel-Hwang
      Ideator II
      Thank you. I solved the problem thanks to you.
      I made a html component in form like below.
      When copy and paste an image from clipboard, it will be uploaded in vault.
      and the uploaded file will be Item's image property.
          <div>
              <img src="" id="pastedImage">
          </div>
          <script>
                  document.onpaste = function(event) {
                      var items = event.clipboardData.items;
                      console.log(JSON.stringify(items)); // will give you the mime types
                      var blob = items[0].getAsFile();
                      var reader = new FileReader();
                      reader.onload = function(event) {
                          console.log(event.target.result);
                          document.querySelector('#pastedImage').src = event.target.result;
                          var file = new File([blob],'test.png',{type:"image/png"});
                          var newFile = aras.newFileItem(file);
                          var fileId = newFile.getAttribute("id");
                          var fileItem = aras.IomInnovator.newItem();
                          fileItem.loadAML(newFile.xml);
                          fileItem = fileItem.apply();
                          window.handleItemChange("_paste_image","vault:///?fileId="+fileId);
                      }; // data url
                      reader.readAsDataURL(blob);
          </script>
