FMEA Master
We aim to establish an FMEA Master function. Based on the information in the Master, DQD and PQD can be generated. Updates made in DQD/PQD should be reflected back in the Master, and updates in the Master should in turn propagate to all DQD/PQD generated from it, allowing users to decide whether to apply the updates. Does anyone have any advice on development and data structure design?109Views0likes0CommentsAras Update (Version 1.22.1328.0): Aras Quality Management System (2023 Release 14.0.1) Download Failed
I am unable to download the correct QMS 2023 package through ArasUpdate Tool. Please help. Note: Looks like Process Quality Binding(PQB) package gets downloaded instead of QMS.83Views0likes2CommentsQuality Module Install error
I'm trying to assess the suitability of using Aras for Quality Management in my organization and am unable to install that module. I've installed successfully Innovator 12 and the sample database; however, when I go to install the Quality module from the Aras Update utility it fails with the error at bottom. I've looked on the forum but cannot find similar failures. Any help that anyone can provide would be greatly appreciated. Thanks! Keith <snip> Import package 'com.aras.innovator.solution.QMS_QS' failed with message: Server error Request: <Item type="Identity" id="CA6D245B9B224A6288F056B33E02097E" action="add" doGetItem="0"><description>Quality Department</description><is_alias>0</is_alias><name>Quality</name><Relationships /></Item> Responce: <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="">www.aras.com/.../faultcode><faultstring><![CDATA[Identity with Name 'Quality' already exists.]]></faultstring><detail><af:legacy_detail><![CDATA[Identity with Name 'Quality' already exists.]]></af:legacy_detail><af:exception message="Identity with Name 'Quality' already exists." type="Aras.Server.Core.PropertiesAreNotUniqueException"><af:innerException message="Violation of UNIQUE KEY constraint." type="Aras.Server.Core.DBUniqueConstraintViolationException"><af:innerException message="Violation of UNIQUE KEY constraint 'C5'. Cannot insert duplicate key in object 'innovator.IDENTITY'. The duplicate key value is (Quality).
The statement has been terminated." type="System.Data.SqlClient.SqlException" /></af:innerException></af:exception><af:item type="Identity" id="CA6D245B9B224A6288F056B33E02097E" xpath="Item"><af:property name="name" value="Quality" /></af:item></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope> Updating com.aras.innovator.solution.QMS_QS to failed release status </snip>39KViews0likes26CommentsFMEA Reports
Hello, Has any one Developed any report for FMEA using query builder? Assume a Program Object(Custom) Connected with 20 FMEAs which has 2 custom Properties Sub System and Components Use Case is 1 . Create a Report which will take input as RPN > any Number (Example : RPN>40 or RPN>85 etc) and give a report of each lines of FMEA which has matching criteria (RPN> number) . Report Should have Export to excel option. 2. Show the top 50 Critical lines for the Program .That means show a report with all lines having top 50 highest RPNs. I tried Creating this report by writing Custom Code where report is static one and i hard Coded the value in Code with RPN>40 . Also this does not have Export to Excel available. Question is can this report be generated using Query Builder ? Or Self Service Reporting tool will be of any help to build this kind of dynamic report ? Thanks Smruti6.3KViews0likes3CommentsInstallation of PQB Package for Process Quality linking between MPP and QMS in Innovator 11SP12
Is there an updated version of the Process Quality Binding (PQB) package available that corresponds to Innovator 11sp12? I have already installed Manufacturing Process Planning (MPP) version 11.0R3 and Quality Management System (QMS) version 11.0R2. I found version 11.0R1 of PQB on Aras update but that does not seem to work because 'not the correct version of innovator'. Is there an updated package already available from Aras that can be manually isntalled? I fnot when can we expect an updated version of PQB on Aras Update for automated isntall? Regards Sachin4.4KViews0likes1Comment
