[ODBC SQL Server Driver] Login timeout expired. Issue during initial Setup.
Hi, I'm trying to install Aras Innovator and create a new database along with it, but I keep getting the error [Microsoft] [ODBC SQL Server Driver] Login timeout expired. I have already installed the SQL Server on my machine and am able to connect to it through SQL Server Management Studio. However, each time I go to connect through the Innovator installer I get the error above. I have tried reinstalling SQL Server, enabling TCP, and have enabled all IIS files needed for installing. Any help would be appreciated.9.4KViews0likes3CommentsHow to roll-up cycle times and costs of MBOM in Aras MPP Process Plans?
At the moment, we can add cycle times and setup times to operations, and cycle times to steps. But this information does not display anywhere once entered. That is fine, but at least if there was the ability to roll-up the cycle times of all the operations in the Process plan, taht would be great. Has anybody attempted this on their isntances? On a similar vein, the phantoms and MBOM only parts consumed have costs associated with them (for ex. I intend to have 'Material' category parts in the MBOM (we use polyureethanes for casting) as the quantity and hence the cost of the material is a process parameter and not an EBOM item. Is there any way to roll-up the 'MBOM cost'? Would appreciate if anybody could point me in the direction of how to set this up Regards Sachin27KViews0likes11CommentsLogin Authentication Failed Innovator 12
Hello Everyone, I am new to Innovator, but am very eager to get up and running. I am in the process of setting up a development database of innovator. I have a Windows 10 Pro machine with a fresh install of SQL server 2017 express. I have installed Innovator 12 on top of that. I configured SQL to allow mixed authentication. When I go to login in for the first time, I get the aras innovator splash screen, but when I type in the default admin credentials described in the installer guide, I get failed login. It appears as though the credentials are invalid. So, then I attempt to use the db owner credentials that I made at setup, that gives me the same error. When I go to SSMS, I will login using the db owner credentials, and I can successfully login to the SQL server. For some reason, I cannot get a successful login from the main screen in innovator. Any thoughts? Thanks in advance!15KViews0likes6Comments
