Hello Gopikrishnan,
Thank you for your inputs.
I checked with all the points you mentioned and everything is in place.
Guessing ASP.NET is not registered with IIS I ran following command
C:\Windows\Microsoft.NET\Framework64\v4.0.30319> aspnet_regiis.exe -i
Now I am getting following error
Hi there,
I think we should not use the URL directly. Instead when I use "http://localhost/InnovatorServer" it pops up the login page.
I just want to chime in and confirm that you should not navigate to /Server/InnovatorServer.aspx directly. Instead, you should login with just the WebAlias that was set up during the installation of Aras Innovator as you have pointed out in your comment. This will redirect you to the appropriate login page.
- gautamk7 years agoIdeator II
Hello Christopher,
Right. Thank you for your comments.
Gautam Kulkarni
