Login error on the PackageImport/Export utility
So recently I installed Innovator V12, after having uninstalled V11. Everything works fine, except when I try to use the PackageImport/Export utility. It gives me the following Error:
Login errors
          ****ErrorMessage****
faultstring: Failed login to Innovator; original error: <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault>
    <faultcode>999</faultcode>
    <faultstring>System.Net.WebException: The remote server returned an error: (401) Unauthorized.</faultstring>
    <faultactor>HttpServerConnection</faultactor>
    <detail>unknown error</detail>
</SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
faultdetail:Failed login to Innovator; original error: <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../" xmlns:i18n="">www.aras.com/I18N"><SOAP-ENV:Body><SOAP-ENV:Fault>
</SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope> Unable to login.
faultcode: -100
I have tried to login with the same credentials in the Webbrowser and it worked. I'm a bit running out of ideas on what to try next to make the utility work. Has anyone encountered the same issue?
Kind Regards,
Matthias
  • asebastian's avatar
    asebastian
    Hi Matthias,
    Are you using the most current version of the import/export utilities? The old version for v11 will not work with innovator 12. The newest version is available within the CD image, or can be downloaded on the downloads page. This new version of the utilities is backwards compatible with 11 as well.
    AJ
    • Former_Member's avatar
      Hi AJ,
      Yes, I'm using the latest Version downloaded a few minutes ago from here: https://aras.com/en/support/downloads
      It gives me the same error
      The old version of the utility gives me the following error:
      Login errors
            999
            HTTP Error
            999
            HTTP Error
             Unable to login.
      faultcode: -100
      Kind regards,
      Matthias
        asebastian
        Interesting. When you input the URL is it in the format: http://{yourIP}/{yourServerName}? Are you able to select the correct database through the import/export utility? I'm having trouble reproducing this issue in my own environment.
        AJ
