Hi Matthias,
Are you using the most current version of the import/export utilities? The old version for v11 will not work with innovator 12. The newest version is available within the CD image, or can be downloaded on the downloads page. This new version of the utilities is backwards compatible with 11 as well.
AJ
Hi AJ,
Yes, I'm using the latest Version downloaded a few minutes ago from here: https://aras.com/en/support/downloads
It gives me the same error
The old version of the utility gives me the following error:
Login errors
****ErrorMessage****
faultstring: Failed login to Innovator; original error:
999
HTTP Error
HttpServerConnection
System.Net.WebException: The remote server returned an error: (401) Unauthorized.
faultdetail:Failed login to Innovator; original error:
999
HTTP Error
Unable to login.
faultcode: -100
Kind regards,
Matthias
