I see you posted on the other thread about this same issue, but I wanted to leave a comment here for people who find this in the future. Aras Innovator 12.0 has new requirements from Aras Innovator 11.0. Please check Section 2.1.2 of the 12.0 Installation Guide and ensure you have all of the pre-requisite applications installed.
This particular issue seems to be most commonly associated with missing the ASP.NET Core/.NET Core Runtime and Hosting Bundle version 2.1.8.
AJ
Hi Sebastian,
Sorry if i posted in other threads because sometimes i don't understand where to post. Thanks for your valuable suggestion, It worked.! perfect.! can i know what are package versions available for Innovator12 to install through Aras update.?
Thanking you.
- asebastian7 years agoCommunity Manager
Hi Ventkatsai,
Not all applications have been released for 12.0 yet. To see which applications are currently available, you can either view the support matrix on the subscriber portal, or you can get that information from the aras update tool itself. When you're looking at online packages you will be able to see available versions. Any application which as a 12R1 version is compatible with 12.0.
AJ
- venkatsai7 years agoIdeator III
Hi Sebastian,
Thanks for your response and valuable information. Yeah i can see 12R1 for only project management. we have to wait until releases for all packages.
- Erlandas7 years agoIdeator II
HI,
Project Management 12R1 already released, or not yet?
Thanks
Hi Erlandas,
Yes it is released, you can download the newest version through aras update.
AJ
