I re-installed aras innovator and got a little further with installing component engineering.
[START LOG]
2017-08-08 17:26:29,182 [INFO ] (9) - Installation of the package started : 'CE' from 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321' directory
2017-08-08 17:26:29,184 [INFO ] (9) - CompatibilityPackage started
2017-08-08 17:26:29,798 [INFO ] (9) - Checking module 'IS' compatibility.
2017-08-08 17:26:29,897 [INFO ] (9) - LoadFile started
2017-08-08 17:26:29,898 [INFO ] (9) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\rev.inc'.
2017-08-08 17:26:29,899 [INFO ] (9) - LoadFile finished
2017-08-08 17:26:29,983 [INFO ] (9) - LoadFile started
2017-08-08 17:26:29,984 [INFO ] (9) - Loading File : 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\scripts\include\build.inc'.
2017-08-08 17:26:29,984 [INFO ] (9) - LoadFile finished
2017-08-08 17:26:30,063 [INFO ] (9) - Custom started
2017-08-08 17:26:30,064 [INFO ] (9) - Custom check the property : 'Version.Check'. The value : 'true'.
2017-08-08 17:26:30,065 [INFO ] (9) - Custom finished
2017-08-08 17:26:30,067 [INFO ] (9) - Checking module 'DB' compatibility.
2017-08-08 17:26:30,068 [INFO ] (9) - Application started
2017-08-08 17:26:47,519 [INFO ] (9) - Variable 'VersionServiceUpdate' is found in DB.The value : '0'.
2017-08-08 17:26:47,520 [INFO ] (9) - Application finished
2017-08-08 17:26:47,521 [INFO ] (9) - Application started
2017-08-08 17:26:47,962 [INFO ] (9) - The innovator DB contains AML package with name : 'com.aras.innovator.solution.PLM'.
2017-08-08 17:26:47,963 [INFO ] (9) - Application finished
2017-08-08 17:26:47,963 [INFO ] (9) - Application started
2017-08-08 17:26:48,003 [INFO ] (9) - Variable 'Component Engineering' is found in DB.
2017-08-08 17:26:48,003 [INFO ] (9) - Application finished
2017-08-08 17:26:48,005 [INFO ] (9) - InnovatorDependence started
2017-08-08 17:26:48,006 [INFO ] (9) - Required version of Innovator : '11.0 SP9'.
2017-08-08 17:26:48,090 [INFO ] (9) - InnovatorDependence finished
2017-08-08 17:26:48,191 [INFO ] (9) - CompatibilityPackage finished
2017-08-08 17:26:48,291 [INFO ] (9) - XmlPeek started
2017-08-08 17:26:48,294 [INFO ] (9) - Found '1' node with the XPath expression '/configuration' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Server\web.config' file.
2017-08-08 17:26:48,295 [INFO ] (9) - XmlPeek finished
2017-08-08 17:26:48,331 [INFO ] (9) - XmlPeek started
2017-08-08 17:26:48,332 [INFO ] (9) - Found '1' node with the XPath expression '/configuration/cachingModule/@filesRevision' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\web.config' file.
2017-08-08 17:26:48,333 [INFO ] (9) - XmlPeek finished
2017-08-08 17:26:48,507 [INFO ] (9) - XmlPeek started
2017-08-08 17:26:48,508 [INFO ] (9) - Found '1' node with the XPath expression '/MethodConfig/ReferencedAssemblies' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Server\method-config.xml' file.
2017-08-08 17:26:48,508 [INFO ] (9) - XmlPeek finished
2017-08-08 17:26:48,605 [INFO ] (9) - BackUpChangedCodeTreeToGit started
2017-08-08 17:26:51,401 [INFO ] (9) - BackUpChangedCodeTreeToGit finished
2017-08-08 17:26:51,411 [INFO ] (9) - Installation module (IS) started
2017-08-08 17:26:51,467 [INFO ] (9) - CopyingFile started
2017-08-08 17:26:51,539 [INFO ] (9) - Copying 100 Files to 'C:\Program Files (x86)\Aras\Innovator\Innovator\'.
2017-08-08 17:26:51,540 [INFO ] (9) - CopyingFile finished
2017-08-08 17:26:51,568 [INFO ] (9) - Program execution started
2017-08-08 17:26:51,586 [INFO ] (9) - Starting 'net (stop w3svc)' in 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321'
2017-08-08 17:26:54,377 [INFO ] (6) - The World Wide Web Publishing Service service is stopping.
2017-08-08 17:26:54,378 [INFO ] (6) - The World Wide Web Publishing Service service was stopped successfully.
2017-08-08 17:26:54,381 [INFO ] (9) - Program execution finished
2017-08-08 17:26:54,394 [INFO ] (9) - Program execution started
2017-08-08 17:26:54,395 [INFO ] (9) - Starting 'net (start w3svc)' in 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321'
2017-08-08 17:26:56,468 [INFO ] (6) - The World Wide Web Publishing Service service is starting.
2017-08-08 17:26:56,468 [INFO ] (7) - The World Wide Web Publishing Service service was started successfully.
2017-08-08 17:26:56,469 [INFO ] (7) -
2017-08-08 17:26:56,470 [INFO ] (9) - Program execution finished
2017-08-08 17:26:56,508 [INFO ] (9) - XmlPeek started
2017-08-08 17:26:56,509 [INFO ] (9) - Found '1' node with the XPath expression '/configuration' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Server\web.config' file.
2017-08-08 17:26:56,510 [INFO ] (9) - XmlPeek finished
2017-08-08 17:26:56,560 [INFO ] (9) - XmlPeek started
2017-08-08 17:26:56,560 [INFO ] (9) - Found '1' node with the XPath expression '/configuration/cachingModule/@filesRevision' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\web.config' file.
2017-08-08 17:26:56,561 [INFO ] (9) - XmlPeek finished
2017-08-08 17:26:56,606 [INFO ] (9) - XmlPoke started
2017-08-08 17:26:56,610 [INFO ] (9) - Found '1' nodes matching XPath expression '/configuration/cachingModule/@filesRevision' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Client\web.config' file.
2017-08-08 17:26:56,610 [INFO ] (9) - XmlPoke finished
2017-08-08 17:26:56,645 [INFO ] (9) - XmlPeek started
2017-08-08 17:26:56,647 [INFO ] (9) - Found '1' node with the XPath expression '/MethodConfig/ReferencedAssemblies' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Server\method-config.xml' file.
2017-08-08 17:26:56,648 [INFO ] (9) - XmlPeek finished
2017-08-08 17:26:56,683 [INFO ] (9) - XmlPoke started
2017-08-08 17:26:56,685 [INFO ] (9) - Found '1' nodes matching XPath expression '/MethodConfig/ReferencedAssemblies' in 'C:\Program Files (x86)\Aras\Innovator\Innovator\Server\method-config.xml' file.
2017-08-08 17:26:56,686 [INFO ] (9) - XmlPoke finished
2017-08-08 17:26:56,687 [INFO ] (9) - Validations started
2017-08-08 17:26:56,704 [INFO ] (9) - There is nothing to validate
2017-08-08 17:26:56,705 [INFO ] (9) - Validations finished
2017-08-08 17:26:56,705 [INFO ] (9) - Installation module (IS) finished
2017-08-08 17:26:56,705 [INFO ] (9) - Installation module (DB) started
2017-08-08 17:26:56,724 [INFO ] (9) - ImportIntoDb started : 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321\imports\CE\imports.mf'
2017-08-08 17:28:11,213 [ERROR] (9) - EXCEPTION STACK TRACE START: at Aras.Tools.ArasUpdateCore.Tasks.Common.BaseTask.Execute()
at Aras.Tools.ArasUpdateCore.Helpers.TaskExecutor.ImportIntoDb(Import task, String packagePath, InputParameters inputParameters)
at Aras.Tools.ArasUpdateCore.Helpers.TaskExecutor.ExecuteTask(Object task, String relativePath, String packagePath, IPackageConfigWrapper packageConfigWrapper, InputParameters inputParameters)
at Aras.Tools.ArasUpdateCore.Implementations.TasksIterator.ExecuteTask(Object task)
at Aras.Tools.ArasUpdateCore.Implementations.TasksIterator.ExecuteTasksNode(TreeNode1 node, OperationResult1& operationResult)
at Aras.Tools.ArasUpdateCore.Implementations.TasksIterator.ExecuteTasksTree(TreeNode`1 rootNode)</strong>
<strong> at Aras.Tools.ArasUpdateCore.Implementations.InstallationModule.InstallModules(IEnumerable`1 moduleInstallations)
at Aras.Tools.ArasUpdateCore.Implementations.InstallationModule.RunInstallation(InputParameters inputParameters, String packagePath, String configPath) EXCEPTION STACK TRACE END
2017-08-08 17:28:11,214 [ERROR] (9) - ****ErrorMessage****
2017-08-08 17:28:11,214 [ERROR] (9) - Aras.Tools.ArasUpdateCore.Implementations.Commands.InstallModuleCommand: ****ErrorMessage****
2017-08-08 17:28:11,240 [INFO ] (9) - System restore using git started
2017-08-08 17:28:11,242 [INFO ] (9) - RestoreCodeTreeFromGit started
2017-08-08 17:28:12,222 [INFO ] (9) - RestoreCodeTreeFromGit finished
2017-08-08 17:28:12,222 [INFO ] (9) - System restore using git finished
2017-08-08 17:28:12,355 [INFO ] (9) - Sending report to the service started
2017-08-08 17:28:14,268 [INFO ] (9) - Sending report to the service finished
[END LOG]
I followed the Program Data/ArasUpdate/CE/11.0.1321/Documentation/Aras Component Engineering 1.0R5 - Installation Guide.pdf
The only install criteria I could not find in innovator was point 2.2 (6) in the pdf
6. Confirm that one of following sets of variables are listed:
Version Major Version Minor Version ServiceUpdate Version ServicePack
11.0 SP9 11 0 0 SP9
I suspect this is not the problem, but a exception in imports.mf
Any help appreciated
best regards
