Nathan's avatar
Nathan
Creator III
Workflow(?) Error - Conversion from type 'DBNull' to 'String' is not valid.
Good day all.  I created a New Document Request (NDR) for our system.  We are trying to test it out now.  I can start the process, but the next person in line gets the Conversion from type 'DBNull' t...
  • Nathan's avatar
    It looks like the problem I had was with the Notification that was assigned to the Activity on the workflow.  Once I removed the notification, everything worked fine.  I believe the notification was trying to pull information about the NDR that was not there, or I told it to pull information that was not there.  I have since redone the notification & everything is working fine now.   Thanks.
