I have seen that nobody answered this legit question yet. Did you find a solution?
Hello Angela,
I did not resolve the issue.
What I did observe though was that it seems everything was packaged correctly.
Here is the SQL Query for a Package check List:
Get Element included in a package Definition
Use [Rheem_Prod_2012-01-21]
Select pkDef.name as "Package Name", pkGrp.name as "Package Group", pkElm.name as "Element Name"
From innovator.PackageDefinition as pkDef
Inner join innovator.[PackageGroup] as pkGrp on pkGrp.source_id = pkDef.id
Inner join innovator.[PackageElement] as pkElm on pkElm.source_id = pkGrp.id
Where pkDef.name = 'rh_OracleMfgBOM_To_eBOM_Staging'
Order by pkDef.name, pkGrp.name Asc, pkElm.name
What I observed was:
1) The Folder level was not created
2) The Itemtypes with icons were assigned to the top level of the TOC
3) The Itemtypes with not icons were not loaded
Resolution create the rest by hand.
Regards
Scott
