RaptureLazarus
5 years agoCreator I
Hi, thanks for your response, It seems you are correct, the string is empty., however the _calibrated_next value is displayed in the grid and item itself.
So it definitely should be getting a value.
Gopikrishnan
5 years agoAccelerator II
Hi
1. Check whether the property name is correct.
2. Is this _calibrated_next is property in item type or on the form ?
3. Debug the method and check the values
Thank You
Gopikrishnan R
- RaptureLazarus5 years agoCreator I
So, strange enough, we had to restart the server machine and it worked flawlessly after that.
Anyway, thanks for your help once again.
