Kai_Kircher's avatar
Kai_Kircher
What is the best way to validate whether an item has a parent?
I'm trying to send an email on promotion to "Released" of Parts when a couple of criteria are met, the parts being of a certain custom classification we've added, and them not being used in another B...
  • Gopikrishnan's avatar
    Hi Kai Kircher
    Easiest way to check whether the item is top level item or not, you can use below code
    Item myResult;
    if (this.getProperty("classification", "") == "Hull Assembly")
    Item checkIsRoot = this.newItem("Part BOM","get");
    checkIsRoot.setAttribute("select","id");
    checkIsRoot.setAttribute("maxRecords","1");
    checkIsRoot.setProperty("related_id",this.getID());
    checkIsRoot = checkIsRoot.apply();
    if(checkIsRoot.isError())
    //email code
    else
    // This item has been used in some Part as BOM
    return this;
    Thank You
    Gopikrishnan R
