Morgan's avatar
Morgan
Creator III
Using a method to update a team, doesn't seem to iterate beyond the first
Hi Community.
I am setting up a method to assign a user to multiple teams based on a form. The issue I am having is that it seems to only apply the user to the first team I select (using a multi-value list). Essentially, I am defining on the form -
The user identity to add
The name of the team to add them to
Their team role and regions they are responsible for
Code is below:
//Get the form used to make the GPR change selections
Item qryGprItem = this.newItem(this.getAttribute("type"), "a_GetControlledItem");
qryGprItem.setID(this.getID());
Item gprItem = qryGprItem.apply();
string[] prodCats = gprItem.getProperty("a_add_to_prodcat").Split(',');
string regions = gprItem.getProperty("a_add_to_region");
string gprAction = gprItem.getProperty("a_add_or_remove");
foreach (string prodCatValue in prodCats)
    string prodCat = prodCatValue;
    Item qryTeamItem = inn.newItem("Team", "get");
    qryTeamItem.setProperty("name", prodCat);
    Item teamItem = qryTeamItem.apply();
    if (gprAction == "Add")
        Item teamMember = inn.newItem("Team Identity", "add");
        teamMember.setPropertyItem("source_id", teamItem);
        teamMember.setPropertyItem("related_id", gprItem.getPropertyItem("a_user_to_modify"));
        teamMember.setProperty("a_team_region", regions);
        teamMember.setPropertyItem("team_role", gprItem.getPropertyItem("a_gpr_role"));
        return teamMember.apply();
    if (gprAction == "Remove")
return this;
  • Can you change this line return teamMember.apply(); to teamMember = teamMember.apply(); and give a try.
    Thank You
    Gopikrishnan R
    Thank You
    Gopikrishnan R
    • Morgan's avatar
      Morgan
      Creator III
      Thank you very much Gopikrishnan, this solution works! I appreciate your reply.
