tmbejoy's avatar
tmbejoy
Ideator II
1 year ago
Updating user role
HI,
I tried to give some role like config management, component engineer, change specialist II role to user. But the part creation and Product creation feature is not getting activated. Is there any wait time it takes for the role to get updated or something? It doesnt seem to updating the roles as per selection.
Regards,
Bejoy Thomas
  • do I need to add from date and end date?
      Certain updates require that you restart Innovator / the browser window. Date is not required. There are some internal help pages that you can check to learn about the most common topics.
      • tmbejoy's avatar
        tmbejoy
        Ideator II
        I have restarted the Innovator but still it doesnt update.
  • Is there any limitation for number of roles one can have?
  • Its working now. I was adding the alias and then adding identities in the alias. which caused the problem. But still how to add multiple identities more than one to a particular user? this is something I am still struggling.
    • asebastian's avatar
      asebastian
      If I'm understanding your question correctly, you should be able to add multiple users to the Member relationship of an identity. This means you could have multiple Change Specialists, and your user could be added to as many identities as they need. They could be a member of Change Specialist as well as Component Engineer.
      Let me know if that doesn't solve your problem!
      AJ
