Eva_DHR
2 years agoIdeator III
If your property is already defined as a Sequence Property you cannot update it - it is handled by Aras. In order for you to change its value, the property needs to be a string property and your code should work perfectly then
2 years agoCatalyst II
Good catch Eva, I guess this was the solution!
