9 years ago
The location of "Choose change item" menu
Hello, where can i find the list of change type selections which are in "Choose change item" currently there are 5 selections Simple ECO ECR ECN etc I would like to rename some of them, any help? Thanks!
  • Hello, Are you referring to the Choose CM Options command from the Actions menu? If so, that action opens a form that is not bound to an ItemType. The form name is PE_ChooseCMOptions. There is a form event configured on the onLoad event named PE_ChooseCMOptions_API. That method is responsible for populating the dropdown lists on the form. Dennis
  • eli_donahue's avatar
    eli_donahue
    Hi Eimantas, If you would like to change the display name of the change items, or any ItemType in Aras, you can simply edit the "Single Label" and "Plural Label" fields in the ItemType definition. Note - I don't recommend changing the "Name" property of any default Aras ItemType, as it may result in unexpected behavior. Changing the label properties is the safest approach. Eli Eli Donahue Aras Labs Software Engineer
