Hi Jeff! I assume you are using RE 12.0 R1 - for this release you will need to update the schema if you chose to add a custom classification. Alternatively you could move to RE 12.0 R3 where custom classes are supported without having to update the schema. Hope that helps!
- jeff_stroh5 years agoCreator II
Hey MIchael,
We're on R2, which I presume based on the above has the same issue as R1? We're trying to get on subscription and our update tool is showing R2 is the highest available for us right now.
As far as updating the schema for added properties against a requirement object, is there anything you could point me to to show what needs to be done there? I'm not an XML expert, but looking at the existing RE-Standard schema type, I don't see a one-to-one correlation between ItemType properties and what's in the schema, so not sure what needs to be done.
Thanks in advance!
- Michael_Pfenning5 years agoIdeator I
Hi Jeff,
ok! I see 2 options: getting on subscription and just using R3 (this is available for subscribers) or configuring the schema accordingly and sticking to R2. For the latter you may need to look into additional documentation for TechDoc Framework as RE editor is based on it.
Could we move the communication to email?
regards,
Michael
