Hi Arnaud,
You should be able to do this by querying the "ItemType" ItemType, and returning the "relationshipType" relationship. More in depth information about how to create queries like this can be found in this blog post.
AJ
Hi Sebastian,
Thank you for the answer, I'm already using this blog but I didn't find the answer... What is the url used to perform this task ? I already tried plenty of things.
I should start with : localhost/.../
But then how can I add "relationshipType" to get the list I need ?
I often get the error message "notImplemented".
Best regards
- cogres7 years agoCreator III
Hi Arnaud,
your request should look something like this
GET <URI for your Aras Installation>/server/odata/ItemType('<ID for the ItemType you want to query>')/RelationshipType
You will need to replace <URI for your Aras Installation> in the URI with the path for your Aras installation (like http://localhost/InnovatorServer) and the given <ID for the ItemType you want to query> with the ID of the ItemType you want to know the RelationshipTypes for.
Is this what you need?
Hi cogres,
Probably, but it returns "value": [].
I have an url like this one :
Airbus_cabin_configuration('AB0358B1D3774D77AC507CA1F857F42E')/RelationshipType
It should return Cabin_seat, Cabin_Lavatory ... that are saved in "RelationshipTypes" in the ItemType, but it doesn't. I don't understand what is wrong.
Best regards.
Hi Arnaud,
The "/RelationshipType" part of the URI means "give me all relationships of the Item specified before that are called 'RelationshipType'". Your custom ItemType "Airbus_cabin_configuration" does not have any Relationships with the name "RelationshipType". Its relationships are called "Cabin_seat, Cabin_Lavatory", etc.
I assumed you wanted to know the names of RelationshipTypes on a given ItemType, not the actual relationship instances on instances of a particular custom ItemType. If you send the request ending in
ItemType('ID of the ItemType Airbus_cabin_configuration')/RelationshipTypethis is exactly what you will get. A collection of "value"-nodes that include the names of your RelationshipTypes (Cabin_seat, Cabin_Lavatory, etc).
If you need the actual instances of these RelationshipTypes on a given Airbus_Cabin_configuration, you will have to combine the result of the above query to get the names of the relationships and then a request likeAirbus_cabin_configuration('AB0358B1D3774D77AC507CA1F857F42E')/Cabin_seat
to fetch the relationship instances.
Is this what you mean?Cheers,
C
